Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
98 Longblocks, LS1 Aftermarket & Stock Stuff
Old Jan 12, 2011 | 06:01 PM
ddr698's Avatar
Default 98 Longblocks, LS1 Aftermarket & Stock Stuff
Category: Racing Parts
Price: $25
Location (State): NE
Item Condition: Used
LS Engine?: Non-LS Part
98 Longblock rebuilt (ringed/honed and bearings) 10k ago - SOLD
98 Longblock core (was motor that came out of the same car as the motor above was in). Bores are clean and good to go, needs bearings. Heads were pulled to check on bores, but they are included. Havn't pulled it apart to check on status of the crank tho - $500
QA1 12way 'r' adjustable front struts with 315lb springs & rear 12way adj shocks, Full set of spanner wrenches included, 1k miles on them only - $650
WS6 Store catch can - $70
Pro 5.0 - $140
B&M short throw shifter - $100
Hurst Billet Plus shifter - $140
Hurst SS OEM style shifter - $100
Edelbrock PN # 70200 Dry nitrous kit. Was $589.99 new. bonus edelbrock bottle blanket included. Instructions manual and everything is there, you may need some wiring thats about it. Comes with an LS1 motorsports lid (another $75 new) that is already tapped for kit - $325
Brute Speed Blower cam with only 1k on it - SOLD
Comp Cams 7955-16 Chromoly 7.4" Pushrods - $95
Spec Aluminum flywheel with brand new insert (pretty much like new at this point) - $300
Spec Stage III clutch (will get measurements later) - $275
McLeod master adj master - $225
Factory Rocker setup with only 65k, 101k or 119k/grimy - $45, $40, or $35
Monster Stage 3 clutch, with lightweight flywheel, 3k miles, Clutch disk is .305-.310" thick, Flywheel has Very minimal hot spotting. Everything is in excellent condition- $500 (was $790 new)
Denny's HD Aluminum Driveshaft w/ $180 Strange U1667 yoke, 3.5", 4l60e/t56 with a 12 bolt, 1350 ujoints - $300
C5 Z06 Front brake conversion, complete setup - $475
Mac mid length headers, with emissions connections with y-pipe (y has a cat in one side and not the other for some reason) - $250
LS1 Aluminum Driveshaft - $100
LS1 front brake conversion for LT1s - $175
Metco solid boxed lower control arms - $125
BMR Boxed lower control arms, red - $95
BMR Track Pak torque arm kit with universal Crossbrace, black - $350
UMI Lower control arm bolt in relocation brackets, red - $65
Double adjustable red BMR panhard rod - $95
Edelbrock boxed lower control arms - $125
White Ultra Z hood (will ship, around $125ish) - $325
Spohn body mounted torque arm, black, driveshaft saftey loop - $325
Granatelli stock style 78mm MAF- $150
Z06 85mm MAF - $45 or $65 with brand new conversion harness
SLP 85mm MAF - $125
Stock screened MAF- $45
Ported-polished stock MAF - $75
Tail light blackouts - $20
Cloth indoor car cover - $35
BMR Track Pak Torque Arm
Spohn Torque Arm
Red are UMI reloc
Old Jan 13, 2011 | 12:33 PM
RyanSws6's Avatar
Will you sell me the MAC Y pipe?
Old Jan 13, 2011 | 12:38 PM
oakfan52's Avatar
Interested in the cam....specs?
Old Jan 13, 2011 | 12:39 PM
killa in progress's Avatar
do u have any ls1 knock sensors
Old Jan 13, 2011 | 02:39 PM
Cheap Guy's Avatar
Default Lid
I know they all look alike but could you post pics of the lid? Does the red "LS1" peel off or is it painted on?
Thanks!
Old Jan 13, 2011 | 04:30 PM
ddr698's Avatar
http://shop.brutespeed.com/Comp-Brut...n-Camshaft.htm
All specs can be found here for it...
BMR Boxed red lcas
Metco lcas
Macs:
Pacesetter w/ypipe:
SOLD
SLP Exhaust:
Old Jan 13, 2011 | 05:53 PM
ddr698's Avatar
If I can find someone who wants the headers by themselves I will...
Sent PMs to the other to of you with questions...
Old Jan 13, 2011 | 08:42 PM
bamaballa205's Avatar
PM Sent on ZO6 MAF
Old Jan 13, 2011 | 08:44 PM
BPG's Avatar
BPG
which springs? whats the max on them? .660?
Old Jan 13, 2011 | 10:03 PM
ddr698's Avatar
They are the gold kit, not the extreme kit so they are the .650" max. The only real difference between the two kits are the retaining locks.
Old Jan 14, 2011 | 04:46 PM
ddr698's Avatar
Kooks headers are sold!
Old Jan 15, 2011 | 07:30 PM
ddr698's Avatar
SFC's and UMI Torque arm are sold!
Old Jan 15, 2011 | 07:51 PM
c6matt's Avatar
looking for the front ls1 caliper standoffs or the stand offs and calipers... please pm me a price.
Old Jan 15, 2011 | 07:55 PM
ddr698's Avatar
I normally sell them as a part of the ls1 brake conversion kit for the LT1 for $175...
Old Jan 16, 2011 | 08:58 AM
ddr698's Avatar
Katech tensioner is sold!
Old Jan 16, 2011 | 09:12 AM
Motovative's Avatar
Pics of spohn TA to brandall@bbxllc.com
Old Jan 16, 2011 | 08:18 PM
ddr698's Avatar
Pics sent to ya, parts added.
Old Jan 17, 2011 | 04:22 PM
ddr698's Avatar
Added some pics above...
Old Jan 18, 2011 | 10:05 PM
ddr698's Avatar
up top!
Old Jan 19, 2011 | 06:53 PM
ddr698's Avatar
Up top!
