Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
AFR 225 #1630 72cc CNC heads Brand New
Old Jan 13, 2011 | 12:36 AM
Rick_Vor's Avatar
Default AFR 225 #1630 72cc CNC heads Brand New
Category: Engine - Intake/Fuel
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): CA
Item Condition: Brand New
LS Engine?: Fits LS Engine
Brand New in Box Air Flow Research AFR 225 CNC 72cc Big Bore LS1/LS2/LS6/ LQ4/LQ9 Cylinder Heads with upgraded .650" lift dual springs. They flow 320cfm intake and 250cfm exhasut @ .600" lift and feature a 3/4" deck and 72cc chambers. These heads are make a great foundation for an all out Forced Induction Turbo or Supercharger build. I was planning on using them on another project but a "new" project materialized so these need to go. They retailed for $2550 + $100 for the #8019 Dual Spring upgrade. SOLD
From AFR's website:
For the maximum street/strip LS1/LS2/LS6 aluminum cylinder heads AFRs all new 225cc emission legal head E/O #D250-4 are hands down the best choice. Specifically designed for 1997 to present Gen-3 Chevy Corvettes, Camaros, and trucks. AFRs LS1 head offers unmatched flow performance and features 2.080 intake and 1.600 exhaust valves with AFRs iron ductile interlocking valve seats. The 225cc is ideal for normally aspirated 396C.I. to 427C.I. For a wild 346 ci the 225 is a good choice, however some low RPM loss of torque might occur. It is available 72cc combustion chambers. AFRs LS1 is a direct bolt on, no special parts required. Structural features like Air Flow Researchs trademark 3/4 thick head deck, a must for blown and nitrous applications, reinforced rocker stud bosses and thick wall runners provide unparalled durability. An exclusive new modern combination chamber design with double quench pad area helps the LS1 generate huge low and mid lift airflow numbers. If you need a snake charmer for that pesky neighborhood Cobra Mustang look no further!
NOTE:
Hydraulic roller cams in "LS" Gen III engines typically experience valve float at 6600-6800 RPM's. If your plan on running over .600 gross valve lift and/or 6600 RPM, AFR suggest you upgrade your springs to AFR part #8019. Our upgrade spring has higher seat and open pressures (155/410+) to better reduce the risk of valve float in more aggressive applications.
THESE HEADS HAVE THE #8019 VALVE SPRING UPGRADE
225cc Intake Runner
2.08" Intake and 1.60" Exhaust Valves (NEW AFR 8mm Valves)
1.270" Diameter Springs - .650"+ Max Lift
100% CNC Ported Combustion Chambers
100% CNC Ported Exhaust Ports
100% CNC Ported Intake Ports
3-angle Raduised Valve Job
1.250 Titanium Retainers #8512
Bronze Valve Guides #9051
Thanks for looking, Rick
Old Jan 13, 2011 | 10:00 AM
tnmotown's Avatar
man those are some sexy looking heads, bump for you!
Old Jan 13, 2011 | 11:56 AM
one fast zo6's Avatar
how about some pics of your truck
Old Jan 13, 2011 | 08:41 PM
Rick_Vor's Avatar
Sold pending payment.
Old Jan 14, 2011 | 06:27 PM
Rick_Vor's Avatar
SOLD
Rick
