Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
9", 12bolt, TCI th400 & shifters
Old Jan 17, 2011 | 05:57 PM
ddr698's Avatar
Default 9", 12bolt, TCI th400 & shifters
Category: Racing Parts
Price: $750
Location (State): NE
Item Condition: Used
LS Engine?: Fits LS Engine
TCI TH400 trans part number 212000 . Fully compatible with LS1 cars (just pick up a ls specific converter or a standard converter with a crank spacer). This trans has 6k on it and is in excellent condition. It is a full manual reverse valve body transmissiob. Shifts firm and has never had a slip. Clean red fluid in it. Excellent. Was $1575 plus $100 pan upgrade, $89 tailshaft/speedo gear. Stall converter pictured in the trans is now sold. $1000 for the Trans only!
Here is a link to it on TCI's website:
http://www.compperformancegroupstore...ct_Code=212000
Trans is stamped with TCI part number and serial number you can verify with them...
Paypal or money order accepted. Currently sitting on a pallet banded and shrinkwrapped. Ready to ship ASAP.
Hurst Pro-matic 2; shifter, cable & base, used 1k - $100
Hurst RMVB quarter stick shifter & cable, used 8k - SOLD
TH400 built by Straightline Performance in KS to Rossler 2 Specs. Never been used since rebuild. Only difference is the valve body is a TCI performance one that is forward and not full manual. Includes 3200rpm Hughes converter that was used for around 10k but in good condition (http://www.summitracing.com/parts/HUP-GM25-400BP/ ). Receipt available. Asking $750 which is cheap enough to ad a full manual reverse valve body WITH trans brake and still be less than Rosslers Term II that doesnt have a brake! And you still have the converter to use or sell!
Moser 9" setup currently for 98-02 ls1 F-bodies. It has 4.10 gears which are fresh from being correctly set up by a GM mechanic that does 2-3 a week (everything was also inspected at the same time, axles, bearings, ring/pinion, etc). Axles are 31 spline Moser. Has a Auburn posi $305 option. 4 channel abs (98-02). Longer screw in style studs for the lugnuts. Nodular Iron center section and aluminum pinion support.
This was a $2600+ Rearend as shipped - $1850
383 LT1 Scat crank & rods, forged Probe -15cc pistons. Excellent condition. 2bolt block. Has 6500 miles on it. Had the normal cleaning, decking, new frost plugs, etc. Clevite bearings throughout. Internally balanced and blueprinted. Fully inspected and is in very good condition - $1750 plus ship
Moser 12 bolt for an LS1 car. It has optional 4 channel abs correct for the LS1. 3.73 Gears and a full spool. Upgraded Moser aluminum stud girdle. Came with coil-over and shock mounts but the coilovers mounts have been removed (aka still direct bolt in with stock components). Excellent condition. No whine or abnormal noise. Has approx 10k on it. Rear cover was removed and internals were inspected. $1850.
Old Jan 18, 2011 | 10:05 PM
ddr698's Avatar
Up top!
Old Jan 19, 2011 | 03:38 AM
lt1773's Avatar
does have transbrake ??
Old Jan 19, 2011 | 06:19 AM
THADD's Avatar
Are the shifters reverse or foward pattern?
Old Jan 19, 2011 | 06:31 AM
THADD's Avatar
Nevermind, I just saw RMVB
Old Jan 19, 2011 | 08:59 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Pm me bottom dollar on shifters please
Old Jan 19, 2011 | 11:11 AM
ddr698's Avatar
The Promatic shifter works with both FMVB and RMVB....
Old Jan 21, 2011 | 03:07 PM
ddr698's Avatar
Up top!
Old Jan 23, 2011 | 12:01 PM
ddr698's Avatar
To the top!
Old Jan 23, 2011 | 01:15 PM
99mongooSS's Avatar
Bottom dollar for 12bolt
Old Jan 23, 2011 | 05:27 PM
ddr698's Avatar
pm'd ya
Old Jan 27, 2011 | 05:11 PM
ddr698's Avatar
hurst quarter stick sold!
Old Jan 27, 2011 | 07:57 PM
Trev_SS's Avatar
Bottom Dollar on the 9 inch shipped to 76262?
Old Jan 27, 2011 | 08:39 PM
MavsFORMULA's Avatar
I'm interested in the 9" bottom dollar shipped as well, to 73170. Very interested.
Old Jan 27, 2011 | 09:42 PM
ddr698's Avatar
Sent pms to both of you...
Old Jan 30, 2011 | 05:45 PM
ddr698's Avatar
A lot of interest in the two rearends but no cash yet....
Old Feb 1, 2011 | 04:41 PM
ddr698's Avatar
Bumping it up!
Old Feb 1, 2011 | 06:17 PM
Busy Mopper's Avatar
how much power will those th400s hold?
Old Feb 1, 2011 | 07:16 PM
ddr698's Avatar
Sent a pm your way...
Old Feb 1, 2011 | 08:12 PM
ws6_z28's Avatar
Interested in a trade for the 9"...Lt1 Vortech S-trim?
