Camaro Transam ls1 ls6 stock and aftermarket parts
Category: Audio/Video/Electronics
Price: $50
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO
Location (State): MI
Item Condition: Brand New
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
SEND PM FOR PRICES.
Exterior Body Pieces:
1*Lambo door kit pass $50
2*RK SPORTS hatch spoiler for camaro 93-02 $125
3*98-02 front bumper has small repair done $150
4*door exterior seals. glass to paint seals dr and pass 15 each
5*antenna. $15
6*RS lower valance spoiler rear $80
7*RK Sport lower spoiler $80
8*Driver and passenger side door ,sold
9*Chassis heat shields$5 each
10*Door hinges$20 each
11*Window metal/felt guide $15 each
12*Front core support for front end damage $150
13*Black roof bar "targa" $250
14*fog lights parts misc$
15*head light bar holds lights $40
16*Front impact plastic with metal support 93-97 /98-02 $30
17*Steering u-joint plastic covers$12
18*Driver window parts mics$
19*T-top body seals on body $90 pr
20*T-top conversion parts mics$
21*Convertible body seals $170 3pcs
22*Convertible pump $190
23*Convertible top arms $150 each
24*Other various convertible pieces
25*Windshield washer res. new $50
26*Windshield washer pump new $20
27*pass door has motor might be slow door not perfect$40
28*steering wheel leather $45
29*steering column for use or parts $60
30*driver power seat track with motor. convert to power $25
31*under dash plastic insulator above feet area $10
32*rear bumper impact plastic $25
33*30mm front sway bar $25
34*20mm rear sway bar $25
35*radiator air deflectors $15
36*air dam under car $10
37*targa band for t top conversion $250 cost new $700
38*driver pass 1/4 panels $100
39*rs hatch spoiler in green no sides $30
40*tan pass rear 1/4 plastic tire cover area small issues $5
42*rear berger panel $65
43*sold
44*sold
45*1993-97 front bumper impact plastic/steel bumper $25
46*sold
47*t top receivers $15 pair
48*wiper motor assembly $45
49*wiper arms 1995 $40
50*hatch popper $27
51*washer res used $15
52*gas door with plastic $20
53*sold
54*lt1 evap can $10
55*driver 1/4 evap vent $5
56*gas cap $5
57*evap plastic lines $30
58*hood strut $10 each
59*hatch struts $12 each
60*rs body body clips $10 each
61*cruise control control and cables$20
Interior Pieces
1*Horns $10ea
2*Hatch popper $25
3*a4 auto center console shifter cover with shift plate $20
4*Spare tire wrench $12
5*Air bag modules $15
7*Stock speakers $20
8*all seat belts in brand new condition
9*used coupe seat belt 30 each
10*Seat belts for convertible $50 each
11* GM stereo amps $30
12*body control mod from 2002 z28 low miles $50
13*1993-2002 convertible trunk carpet 30
14*1993-2002 trunk carpet $30
15*air bags 93-02 $50 each
16*tan cargo cover $25
17*gray cargo cover one pivot gone still very nice cover $22
18*t top left or right $60 ea
19*lots of body electrical ends
20*hvac controllers $25
21*speaker grills $10ea
22*gm stereo amps monsoon $30
23*ls1 front fuse box plastic holder, brand new condition. $25
26*97-02 radio bezel $25
27*2002 ls1 cluster very low miles like new 2500 $150
28*cluster 0-120 mph v6 from 1999 $80
29*cluster 0-150 mph v8 from 1997 $80
Engine:
ls1 engine part
1*upper air box removed when new $70
2* ls1/lt1heater core removed when new $50
3*ls1 ac pump and bracket with tenstioner used 100
4*lq4 suv starter new $120
5* LS1 cam from 2001 vette w/ springs, locks $125
6* LS6 valve cover center bolt like new $75
7*ls1 y pipe pipe like brand new $95
8*ls1 k member $150
9*ls1 gas lines new condition $100
10*ls1 upper and lower mounts $80
11*sold
12*2002 ls1 heater hoses brand new condition $70
13*ls1 fuel rails from stock ls6 intake like brand new $50
14*ls1 fuel pump used 100 miles like new oem $60
15*ls1 rocker arms used 50 pr
16*use ls1 valve covers pair 1 need fixed edge crack $25
17*ls6 balancer used 1 hour ctsv $60
18*ls1 balancer $60
19*valve cover bolts used $15
20*ls1 5.3 truck pan and pick up $50
21*ls6 oil pump used 1 hour 75
22*ls1 new rad hoses with PS cooler new $11
l 23*s6 .561 cam like new. used 1 hour $220
24* hot camclose to hot cam bit more aggressive
25*comp lsr .647 cam like new used very little 300
26*ls1 steam pipe $30
27*ls6 water pump used 1 hour like new. $195
28*ls1 intake bolts $22
Fueling:
1* Gas tank bare $25
2* Gas tank straps $10
3* Gas cap door $10
4* Gas cap $5
5* Fuel pump lt1 $50
6* Fuel rails lt1 $30
7* Fuel rail to long fuel lines lt1$85
8* Fuel line and return from gas tank to lower fuel line connection (longest lines on car) $85
9* v6 fuel pump used complete $90
Braking:
1* E-brake handle $20
2* E-brake cables $25
3* LS1 front calipers{no bleeder} $90 pr
4* LS1 rotors need turned $10 each
5* LT1 spindles $65 ea
6* LT1 calipers $40 ea
7* LT1 front and rear rotors $10ea
8* master cylinder $40
9* V6 drive by wire pedals 1999 $50
10* V6 brake pedal single 1999 $40
11* Brake booster $50
Exhaust:
1* LT1 Y-Pipe no cat $40
2* LT1 Exhaust Manifolds need bolt removed $40
3* ls1 y-pipe new $120
4* ls6 corvette manifold $50pr
Wheels/Tires:
1* Pro stars with M/T used one day on 1997 z28 comes with hardware/ rubber pd 1400 sell 1025
2* BF Goodrich Extreme T/A Drag Radials 295/25/18 used very little 520 new sell 350
3*summito 275/40/17 set 10 miles on them 150 p/u
Drive train and Misc.:
1*Used 10 bolt 3:42 gear set low miles $95
2*Most nuts bolts for whole car
3*lt1 t56 slave spacer $25
4*used slave assembly $35
5*tunnel sheet metal for a4 to t56 $25
6*clutch, flywheel, pressure plate, clutch bolts,{need surfaced} $130
7*t56 cross member $50
8*auto trans tunnel brace $5
9*sway bar mounts upper $15 pr
10*sway bar lower half's $15 pr
11*rear bump stops one bit lose on edge $25 pr
12*steering u joint plastic covers $12
13*front spring and struts low miles $100
14*rear spring isolator $20 pr
15*stock lca $25 ea
16*sold
17*sold
18*sold
19*many misc lug nuts from 93-02 2 each
20*body elect ends mics,cut so you can repair yours
misc lt1 and ls1 nuts and bolts from 4th gen f body
Can you send pics of these items, please? I'm very interested.
Thanks,
Brandon
jbrandon3@yahoo.com
Thanks,
Brandon
jbrandon3@yahoo.com
