MTI B1, LS6, CARTEK 2x, Comp Pro Magnum,Pacestter, QTP
Old Feb 17, 2011 | 06:37 PM
1QWIKBIRD's Avatar
Default MTI B1, LS6, CARTEK 2x, Comp Pro Magnum,Pacestter, QTP
All parts are used. All are in good condition, with no known flaws. Most came off my 346 which put down 419+/- to the wheels and backed that up by running 117-121 mph out the back door at the track (weather/traction dependent). Proven combo that was very very easy to drive. My motor is being rebuilt and upgraded so this stuff is now available.
Cam is smallish and an older grind, but is a performer. MTI B1 grind.
.558/.558 221/221 114
$150 for the cam SOLD
Oil pump was bought from thunder racing, 3 years ago and has 12,000 miles on it. No issues. $50 SOLD
Pacesetter/Jet Hot Longtubes could use a recoat or just some cleaning up and some high temp paint. No warped flanges, hammer marks, crushed tubes or other nonsense. These don't have air/egr. 1-3/4 primaries with 3" collectors. $100 SOLD
Y-pipe with hollowed out cats is also available, has Flowmaster merge, with bullet muffler and a "Y" installed for a cutout. $50 SOLD
Also have a set of QTP stainless headers, no air/egr, 1-3/4 primaries 3" collectors, good shape with some discoloration. $500 Pics coming.
SOLD
LS6 intake with ported TB and 28.8lb injectors. No sensors. Fuel rail might be available if I get one in return. New set of Fel-pro gaskets included. No cracks, epoxy work or porting done. Needs a good cleaning, but is otherwise ready to go. $425 for everything. SOLD
Cartek Stage 2x heads. 241 castings. Don't be fooled because they aren't as sexy as 243's. The heads make power and are 100% fresh from the machine shop with top quality components. NEW Manley Racemaster Intake valves 2.02, factory exhaust valves, Manley Nextek Dual springs good to .660 lift with all new Ti retainers, steel locks, valve seals. The chambers, runners are clean. No shortcuts were taken with these heads or components. I had them rebuilt with the idea I was going to use them on my motor. I don't think they were ever milled, but can get them CC'd if necessary. Great street/strip head for a 346. You would be hard pressed to duplicate with the same hardware for the money. They have zero miles or run time since being rebuilt. $1000 SOLD
Flow numbers:
Int. Exh.
.200 145 111.2
.300 202.4 147.5
.400 244.7 179.2
.500 270 196
.600 287.7 207.7
LS1 oil cooler adapter for side of oil pan. Has -8 (I think, mayb -10) In/Out ports, NPT taps for oil temp/pressure. Complete with hardware and gasket $50
http://www.flickr.com/photos/1qwikbird/5454814404/
Also have the stock crank, needs to be turned 010/010 $75
Also have eight rod/piston assemblies (not rod bolts though) $10 each $50 for all
LS2 Timing Chain $15 SOLD
Comp Cams Pro Magnum Roller Rockers 1.75 ratio, complete with studs/guideplates etc. Good Shape. $225
LS1 Factory Rockers with Harland Sharp Trunion upgrade and hardware with factory stands $150
Everything is available for inspection and reasonable offers are welcomed. Cash in my hand speaks, paypal is fine (I'll eat the fees). Shipping is on YOU.
Willing to meet up within reasonable distance. If you want or need additional pics or any particular item, just ask. I generally don't have access to the internet during work hours, so be patient on the PM's please.
If you are still planning your build or not sure what you want or don't have money, or think lowballing is :rofl: please don't waste your time or mine.
Would consider the following in full/partial trade:
1-7/8ths stainless headers (Kooks, ARH, Stainless works) new or good used
Yella Terra Ultra Lite 1.7 rockers (new)
Jesel Rockers (new)
Chris
Last edited by 1QWIKBIRD; May 20, 2011 at 11:58 AM. Reason: more pics, update, update
Old Feb 17, 2011 | 08:16 PM
itsslow98's Avatar
Pm sent
Old Feb 17, 2011 | 09:52 PM
1QWIKBIRD's Avatar
Oil pump and timing chain sold.
Old Feb 17, 2011 | 10:51 PM
tmurph01's Avatar
Pics of QTP Headers.. highly interested...
Old Feb 17, 2011 | 11:16 PM
1QWIKBIRD's Avatar
Pics are up.....
Old Feb 18, 2011 | 04:36 PM
dannyo210's Avatar
pm sent
Old Feb 18, 2011 | 05:43 PM
1QWIKBIRD's Avatar
All pm's relied to....
Old Feb 20, 2011 | 02:18 PM
1QWIKBIRD's Avatar
Update. The following items are sold:
Heads, Pacesetters, Y-pipe, Cam, Oil Pump, Timing Chain
Old Feb 22, 2011 | 07:13 PM
1QWIKBIRD's Avatar
Intake/TB/Injectors/Fuel rail Sold.
