camaro parts super list!!!
Category: Drivetrain
Price: $25
Location (State): MI
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
shipping is based on your zip code, for pics include you email, not everything is priced ran out of time, pm please
Interior Pieces******************
Horns 10
2002 z28 air bags with 100 miles 95 new
shift plate (1st on shift plate) 5
Spare tire wrench 10
1999 v6 dash cluster 70
2002 ls1 bezel with 2000 miles 150
Air bag modules 20
Stock monsoon speaker 40
Seat belts 95-97 30 each
seat belt for convert 2001 set of 4 130
GM stereo amps monsoon amp 30
cover below steering wheel 93-96 0r 97-02 25 gray
insuators under dash driver or pass 10
Body control mod. from 2002 z28
1993-2002 convertible trunk carpet 30
1993-2002 trunk carpet 30
steering wheel leather some wear leather nice 40
steering column for use or parts 60
driver and pass door switches 10 per switch
gray and red rear seat back 10
under dash plastic insulator above feet area 10 ea
tan ************************************************** ********
rear spare tire area cover 10
tan oem floor mats used 20
new tan floor mats not oem but brand new 25
speaker covers 8
drivers door handle bezel
pass door bezel 20 repainted
93-96 fuse cover 15
97-02 fuse cover 20
97-02 vent bezels 8
1993-96 vents 8
consel shifter bezel with shifter id 93-96 20
tape holder 93-96 5
consel filler 10
T-top body seals 80
T-top conversion parts ask
t-top dr or pass $70 each
Convertible body seals 3 pcs low miles $150
Convertible pump $150
Convertuble top arms $200 (dealer 450 each)
Other various convertible pieces ask
driver or pass floor pans 50
v6 drive by wire pedals 1999 50
v6 drive by wire brake pedal single 50
convertible body seals 150
tan cargo cover 25
air bags 93-02 50 ea
driver window parts 25
air bag modules 15
Engine:
lt1 fuel lines 90
HVAC controllers w/ ***** 25
LT1 valve covers 25
LQ4 suv starter 125
LT1 oil cooler mount 30
LS1 stock cam from 2001 vette w/ springs, locks 150
Evap system for fuel tank, located in drivers 1/4 near gas cap. 15
Evap lines to gas tank 20
LS1 valve covers 1 need repair 30
LT1 opti 1 timing cover 50
LT1 opti 2 timing cover 50 not crank sensor type
lt1Power steering pump 75
lt1 1995 opti spark 75
LT1 coil 15
LT1 idler pulley 15
LT1 electric fans 70
LT1 head coolant tubing 25
LT1 alternator 75
LT1 motor mounts 75
LT1 cam and lifter, guild plates spider 100
LT1 Oil pan 40
LT1 374 alumimum best for porting need small repair 150
Lt1 Bare intake 50
Lt1 Bare throttle 35
LT1 Injectors 80 for 8
lt1 water pump 6 bolts 15
LT1 bypass coolent bolts 8 each
LT1 Water pump drive gear with bearing 30
LT1 Water pump drive coupler 10
LT1 balancer 35
LT1 hub 35
LT1 new lt1 oil pan 65
LT1 oil level sensor 25
LT1 crank 125
LT1 piston and rods 80 for 8
lots of misc lt1 parts just ask
LT1 t56 clutch , pressure plate 130
ls1 kmember 175
lt1 k member 150
ls1 motor mounts 88
lt1 motor mounts upper lower 80
LS1 valley cover 25
LT1 evap silnoid 15
LT1 egr 15
LT1 FUEL RAILS 35
LT1 injector set 80
Windshield washer res. 25
Windshield washer pump 10
Fueling:LT1
lt1 fuel rail 30
Gas tank bare 20
Gas tank straps 5
Gas cap door 10
Gas cap 5
Fuel pump 45
LS1 Fuel rails 35
lt1 valve covers
lt1 alt
ls1 gas lines
lt1 gas lines
v6 fuel pump used few miles used
lt1 fuel pump used
lt1 tank
throttle body cable plastic cover
idler pulley lt1
lt1 injectors
LT1 OR LS1 rad over flow tank NEW 65
Braking:
LT1 spindles 100 each
LT1 calipers 60 pr
LT1 front and rear rotors 10 each
master cylinder 35
V6 drive by wire pedals 1999
V6 brake pedal single 1999
Brake booster 30
lt1 t56 clucth and pressure plate 100
e brake cable, goes on the ebrake handle to connect rear 25
torque arm mount 25
shifter lock out a4 20
many lt1 brake related parts
Exhaust:
new ls1 y pipe 125
LT1 Exhaust Manifolds 70
ls6 exahust manifolds good for turbo 80
exhaust hangers rear or center 15 ea
Wheels/Tires:
set of 2bf goodrich comp ta 275/40/17 90 pr ship est 60
set of 2 summito 275/40/17 new 150 ship est 60
prostars for ta or camro rims 625 100-150 ship est
Drivetrain and Misc.:
10 bolt 3:42 gear set in box 100
Most nuts bolts for whole car
lt1 rack pinion 80
Rear lower control arms 25 each
track bar 25
LT1 drive shaft 40
heater core 20
heater blower 15
ac coil 20
auto trans tunnel brace 5
spare tire wrench 10
sway bar mounts upper 6 EA
sway bar lower halfs 6 EA
steering u joint plastic covers 10
front spring and struts low miles 120
rear spring isolator 20
stock lca 25 ea
Exterior Body Pieces:
targa band for t top converstion
driver and pass 1/4 panel for rust repair
stock z28 deck spoiler in black very clean
rear bumper impact plastic
30mm front sway bar
20mm rear sway bar
radiator air delfectors
air dam under car
rear berger panel
rs lower valance rear
rk sports lower valance rear
1993-97 front bumper impact plastic/steel bumper
Lambo door kit for passenger side door 95
Chassis heat shields
Door hinges
Black roof bar hard to find 200
LT1 Front impact plastic with metal support
Steering u-joint plastic covers
Head light mounting bar
Driver window parts
pass or driver glass 35 EA
rk sports high hatch wing about 5" cart type 170
pass door 93-02 60
nuts bolts from few part outs most 93-97 some 2001
door exterior seals. glass too paint seals dr and pass 25pr
wiper motor 35
wiper arms 30 pair
berger rear panel 60
hood struts 25 pr
hood hinges 15 each
hatch struts 30 pr
passenger door 93-92 $60 with glass
RK Sport rear hatch spoiler $ 125
RS lower valance spoiler in black $90
RK Sport lower spoiler dual cut out for exhauste tips $125
set Chassis heat shields $25
Door hinges pass $20 ea
Front core support if you bent your front end $125
Black roof bar for t-top cars with screws $40
lt1 Front bumper impact plastic with metal support $25
Steering u-joint plastic covers $10
lt1 Head light mounting bar $45
Driver window parts $25
windshield washer res 20
gas door with plastic 10
chassis heat shields 25 for set
SMALL PARTS
Pass door triangle 20
driver door triangle 20
lt1 wire loom 5
tan rear interior spare plastic screw 1
a/c fill caps 3
rad cap 2
t56 custom chrome shift knob5
seat belt bolts 2 each
lt1 thermo neck 10
interior clothes hook 2
door latches 5
lt1 throttle bracket 15
hood bumpers 2 ea
washer fluid cap 3
ac expantion valve 6
dr or pass window felt guild 8 ea
door stricker 5
trunk latch w/key 10
seat belt screw cover 2
lt1 oil cap 5
brake pedal switches 8ea
lt1 valve cover pvc grommit 2
batter hold down clamp 5
rad bottom iso rubber 5
new fuel filter clamp 5
seat nut cover 1
hood strut ends 2
rs grd fx mounts 8 ea
air cleaner clamps s.s. Common lost 8
t top reciver 10 ea
body rubber plugs 2
coin holer 4
fuel line locks 2
consel insert holder 5
spare jack t bolt 5
tail light t nuts
spare tire large hold down washer 5
heater ***** 3 each
ashtray 5
various push type retaines for car 1ea
misc body emblems 10ea
hood isualtion buttons 2ea
rad hose tee 10
body u clips 2
horn button switches 5ea
head light adjuster 5 ea
can i have pics of Lt1 style air vents,grey cover thats underneath steering wheel,fuse cover for Lt1. Do u have LS1 style a/c compressor w/lines and drier? Please send pics to joshuardz@hotmail.com
