Spring locators/bases for Patriot gold/comp921 etc with larger bronze guides.
Old Feb 21, 2011 | 07:20 PM
Steve01SS's Avatar
Default Spring locators/bases for Patriot gold/comp921 etc with larger bronze guides.
I have a new set of patriot gold springs, but I actually need the larger .565"ID spring bases/locators for my heads which have larger OD bronze guides. The supplied .505" ID bases will not fit. Comp 921 would use the same size bases that are also 0.060" thick. The 4695-16 (supplied with a 921 or 926) Comps are also too small ID. I know someone has to run a 921 etc with bronze guides. PRC's should be the same also.
Is there an off the shelf comp or etc that I can just order a set of. I guess I could contact patriot, but was wondering if anyone had a quick simple answer.
Steve
