Billet flywheel, Textralia, 12 bolt spool & 4.56s, Weld Draglites, Gauge Pillar Pods,
Category: Audio/Video/Electronics
Price: $1
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
I will take PayPal, but you cover the fee. You also cover shipping. I'm not in a rush so please don't waste our time with lowball offers. Fair offers will be considered.
Read on for LSX parts, LT1 parts, and 4th gen chassis parts.
LSX Parts
-Moser Engineering Series 3 Spool, 35 spline, with bearings, like new. Very little use $150
-Richmond Series 4 4.56 gears for 12 bolt, very little use, setup up properly, did not whine. Comes with almost new, good pinion bearing Switched to 4.10 $100
-Nitrous Outlet digital window switch - Built in window switch and WOT switch, activates 2 stages http://www.trickperformanceproducts.com/tpp_00011.htm $100
-Ram Billet Steel SFI flywheel for LS1 F body. Less than 400 miles, like new. Does not need surfaced.$150
-Textralia OZ700 clutch disc - Like new, less than 400 miles. The pressure plate has a bent torque strap so it is no good, but the disc almost like new. It will work with other clutches$100
-Weld Draglites 15x3.5 with Hankook 165R radial tires. Center caps, lug nuts, and spacers included. Wheels and tires are two years old. They were only used when going to the track and have 95% tread remaining $400
-T top shades, GREY in color. Good condition but not perfect $45
-Single gauge pillar pod installed on GREY factory A pillar trim. its 93-03 Trans Am/Firebird and 97-02 Camaro WITH T TOPS or convertible $30
-93-97 Trans Am driver side fender, silver, good condition $50 LOCAL PICKUP ONLY
-93-02 Trans Am or Firebird driver side door, complete with glass and regulator $100 LOCAL PICKUP ONLY
-Fire extinguisher - 1lb unit with storage bracket. I had this mounted in my glove box. Like new, never used. $45
-Stock Trans Am catback exhaust $50 LOCAL PICKUP ONLY
Bear with me if I am slow to respond to PMs fellas. I am getting blown up! For those of you that ask for pics, I may not respond until I have pics ready, so just bear with me. Thanks!
-Nitrous Outlet 00-11005 ash tray switch panel for 93-02 F body,
-Racetronix Fuel pump kit for 98 F body, pump installation kit and harness all for 160.00
