SOLD - Chrome Moly Pushrods - Trick Flow (7.400")
Category: Engine - Intake/Fuel
Price: $55
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
$55 shipped to US !
Brandon
jbrandon3@yahoo.com
From Summit Racing:
Get all of the performance that your engine can produce with these durable pushrods designed especially for high-lift cams. Trick Flow® pushrods are available in both 5/16 in. and 3/8 in. diameters. They feature .080 in. wall thickness and are formed from 4130 chromemoly steel. These one-piece Trick Flow® pushrods are heat-treated for use with guideplates. They close their tips, and then the oil holes are drilled and chamfered to .093 in. to prevent stress fractures and cracks.
From EPP (Exotic Performance Plus):
Maintain Proper Valve Train Geometry!
Chromemoly Pushrods
The proper length pushrod is critical to achieving correct valvetrain geometry. Our one-piece chromemoly pushrods are available in a variety of lengths for use with any type of OEM or aftermarket heads.
Designed specifically for high performance usage, the pushrods incorporate the following features:
· Cold formed from 4130 chromemoly steel construction
· .080" wall thickness
· Induction hardened heat-treating for use with guideplates
In addition, the oil hole is closed to within .040", then drilled and chamferred the holes to .093" to eliminate stress fractures and cracks caused by the cold forming process. They’re available in sets or individually.
NOTE: Always check the proper pushrod length for your specific application before ordering.
Exotic Performance Plus Tip: The stock LS1/LS6 pushrod length is 7.400". The GM/Lingenfelter LS6 11.1/1 compression heads typically take the 7.350" pushrods. These Trick Flow Pushrods are a nice piece that we use in a lot of our engine rebuilds.
