Clearing out garage, suspension, braking, engine, OE stuff
Category: Racing Parts
Price: $0
Location (State): PA
Item Condition: Brand New
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
https://ls1tech.com/forums/vehicles-...6-h-c-lt1.html
Check back as I'll be updating with more stuff to sell!
-(8) Ferrea small block Chevy generations 1 & 2(LT1/4) 6000 series exhaust valves, #F6100, 1.600, 11/32 undercut stem, +.050" long, radiused head, 30* backcut, EC, $50
-(2)Severn Motorsports front brake vents, I used these when I road raced my Z28. These are not available from Severn anymore. They bolt on at the wheel bearing to spindle bolts. 3" stainless steel, EC, $50
UPDATE:SOLD to s/c'd cav, Thanks!
-(2)LG Motorsports aluminum double adjustable rear LCAs with rod ends. If you are serious about having an F-bod turn, these are must haves, zero bind! Yes, they allow more road noise/harshness but it never drove me over the edge. If you want some dampening, check out the next item. One rod end has more wear than the other three, but it still is good and the LCAs are ready to bolt in. Comes with rod end boots to keep dirt out. Will work with 3rd gen F-bodies also. EC, $100
UPDATE: SOLD! Thanks mudluver27!
-(2) Lefthander Chassis rubber bushing assemblies for the above LG LCAs. These will screw into the aluminum LCAs on one end and the rubber will dampen the road noise. I did use these on the street for some time, and just swapped them out to reinstall the rod ends when I went to the track, EC, $25
https://www.lefthanderchassis.com/v2...dgroup=2513474
-(8) Airflow Research pushrod guideplates. These came off my AFR 190cc LT1 heads of 1998 vintage. EC, $5
UPDATE: SOLD! Thanks spilner!
More stuff to follow!
More Pictures and info on request! PM (I prefer a PM)or email me! If you want to Email me at: cdb95z28@yahoo.com
>>>If interested, PLEASE give me your city/state/zip so I can get you a shipping cost quickly!!!! <<<<
Shipping is paid by buyer based on method, weight, size of package and location. Money order or PAYPAL. I prefer PAYPAL. I`ve sold many parts in the past, especially some expensive stuff. (camaroz28.com,ls1tech.com,frrax.com, g8board.com, most recently at gm-trucks.com>>> all under cdb95z28 username and cdb09g8gt at grrrr8.net). Search cdb95z28 on Google, you'll find damn near every post on those websites. I aim to please.
Thanks for looking!
-Chad
More stuff:
-Russell stainless steel ProFlex hose, -10 size, 4'9" length, brand new, never used, EC, $15
-(2) Russell -10 flare x 1/2" NPT adapter fittings #660500, blue anodized, brand new, never used, EC, $3 each
-The following is all from my 1995 Z28 OE (original equipment)parts, various mileage, under 35,000 miles, most alot less than that:
-air intake ducting, filter, modified filter housing, probably about 7000 miles, EC, $10
-LH front upper shock/spring mount. This is one I picked up on a trip to the junk yard for something else, just because, EC, $5
-stock 48mm throttle body with IAC and TPS, clean, UPDATE: after exchanging some PMs with a fellow forum member, I do not know what year this TB came from. I recall sending my OE TB to TPIS back in the day for one of their 52mm units. EC, $15
UPDATE: SOLD! to iWon, Thanks!
-The following are in one pic:
-EGR tube, EC, $5
-rear anti-roll bar end links, EC, $2
-(2) 180* thermostats, EC, $2
-oil pump drive gear, EC, $2
-timing set with water pump drive gear, about 20,000 miles, EC $5
-disregard the TPS in the pic, it goes with the throttle body.
More to come.
More Pictures and info on request! PM or email me! If you want to Email me at: cdb95z28@yahoo.com
Shipping is paid by buyer based on method, weight, size of package and location. Money order or PAYPAL. I prefer PAYPAL. I`ve sold many parts in the past, especially some expensive stuff. (camaroz28.com,ls1tech.com,frrax.com, g8board.com and most recently gm-trucks.com all under cdb95z28 username and cdb09g8gt at grrrr8.net). Search cdb95z28 on Google, you'll find damn near every post on those websites. I aim to please.
Thanks for looking!
-Chad
-EGR tube, EC, $5
More to come.
Thanks for looking!
-Chad
-(16) Comp Cams Hi-Tech pushrods, 5/16" diameter, .080" wall, one piece construction, heat treated chromemoly, 8.000" long, #7995-16, 4300 miles on them. These are what I used when I had a Comp solid roller in my Z28 back in 01-02, kinda an oddball length , but that is what my engine wanted, they are straight, EC, $40
-Dr. Gas 3" round to oval to round 3" transition. 11" long. I bought this thinking it might work good on the driver's side floor when used with long tubes. That part of the floor, if memory serves me correctly, pushes the exhaust of a LT system towards the ground, there is not much clearance for a 3" pipe/y-pipe. I thought this piece would allow the pipe to be tucked in a little closer to the floor. Eventually I ended up going with the SLP shorties for the road racing which is set up like the stock exhaust.Brand new, never used, $20
-1 1/2 quarts of Redline 75W140NS gear lube, good stuff, I used it with my Torsen T2R diff in my 7.5" 10 bolt. I believe you cannot use it with a clutch or cone type diff. $10
http://www.redlineoil.com/product.aspx?pid=39&pcid=4
-Howell air/fuel ratio monitor. This will tap into you non-wide band oxygen sensor (stock or standalone). Fitted with the following terminals: 12V+, 12V- and O2 sensor signal. EC, $10
Energy Suspension rear anti-roll bar end links. I used these when I had a Currie Ford 9" rear in the Z28. They worked with the OE rear bar and they are about 1" longer than the stock ones.EC, $5
-Energy Suspension greaseable rear anti-roll bar mounting bushings, # 9.5158RC, 7/8" (22.2mm)ID, EC, $5
Thanks for looking!
-Chad
Thanks for looking!
-Chad
