LS1 block, trex cam, Aluminum drivshaft, 10 bolt rear
Category: Drivetrain
Price: $1
Location (State): VA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have a Comp trex cam 610/615 lift, 243/248 dur, 110 lsa. Has arond 5k miles. Sold
Last, I have an Aluminum drivshaft out of my 2001 camaro. set up for t56 to 10 bolt rear. $150 obo
I have 10 bolt rear end out of a 2001 camaro. the carrier will need to be replaced. Has 3:73 gears. 4 channel abs. $150
I will have pictures up soon, or i can send pictures of all items as requested.
on the back head bolt, someone tried to torque the head down with some liquid in the bolt hole. it blew a piece of the block out. Its not hurting anything, and its not in the threads. The heads still torque down correctly.
OK, but, what about the rotating assy? Are the crank, rods, pistons still in the block & not-damaged?
Like i said it spun a rod bearing, so the crank will need to be turned. Really, all thats good is the block and the rods. pistons are in ok condition but they have 100k miles on them.
What do you mean "like I said,?" If you had "said it," I wouldn't have asked. Info regarding the condition of the rotating assy were never posted. You've noted pretty sketchy details & replies; I'll pass.
