FS: Turbonetics TC76 Polished w/Ceramic Coating
Category: Audio/Video/Electronics
Price: $800
Location (State): NY
Item Condition: Used
LS Engine?: Fits LS Engine
The turbo is used and has roughly 20k miles on it. Most of that is from when it was on my STS setup. It has a polished compressor cover and a ceramic coated exhaust housing which helps keep the heat in.
There is no thrust play in the turbo and it is in great shape overall. Both the turbine and compressor wheels are in great shape as well.
I'm asking $800 + shipping. There ceramic coating alone was $100.
SOLDSOLDSOLD
Thanks,
Adam
It's hard to say because of the converter. When you're on the throttle, you're never going to be at 3000 rpm. Put it this way... when going down the expressway at 2000 rpm with the converter locked I could lean on it a little and get 8-10 lbs at 2000 rpm before the converter would unlock and the could would take off. I only have a single disc so I don't keep it locked with much force.
