Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Cleaning out the garage...
Old May 13, 2011 | 09:58 PM
RacerBill's Avatar
Default Cleaning out the garage...
Category: Audio/Video/Electronics
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TN
Item Condition: Used
LS Engine?: Fits LS Engine
Alright guys, it’s that time of year again… spring cleaning. This is actually the first time I have ever had this problem since I move so much, but this one is mainly due to the recent swap I did, although some of it is stuff I have been tagging along for some reason. Here goes…
*All pricing doesn’t include shipping or paypal fees… where applicable*
FYI, LaTechGTO is my handle on other forums...
04 GTO Engine Covers
There is a hole in the drivers’ side cover because it was where my FPSS was located on my stock fuel rail a long time ago when I had nitrous. The paint job desperately needs to be re-done.
$50
Remote Bottle Opener (I believe it was $250+ new)
It’s basically brand new.
$Sold
LS1/6 Fuel Rails
One is missing the Schrader and the other is complete.
$50/ea
Stock GTO Shifter
Complete with even the rubber gasket.
$SOLD
Nitrous Express 10# Bottle and Harris Speed Works Billet Bottle Bracket
Bottle has normal wear. The billet bottle bracket comes with hardware and is basically brand new.
Bottle - $100
Bracket - $150
Stock 04 Rear Diff
No whine or any issues known
$Sold
04 MAF w/Ported Ends
Working when taken off, however I would suggest it be cleaned with some electrical parts cleaner before use
$Sold
Classic Tube SS Line
I’m pretty sure this runs from the master cylinder (positive on this part) to the slave fitting.
$Sold
Torrent Billet Fuel Rails w/black Fittings (I believe it was close to $190 for the rails, $150 for the lines and $25 for the replacement factory conncetion line new)
No Issues; I just got new rails with my Lonnies Kit
$Sold
Stock 04 Halfshafts w/hardware
No caps on one end of each shaft; I had them installed with 2-piece 300M stubs so the caps wouldn’t fit.
$100
RacerBill's Avatar
Stock Master Cylinder
It was working fine when removed; Replaced with Tick Master Cylinder
$100
Stock 04 Fuel Bucket
No issues. This would be great for anyone wanting to mod or send off without having downtime.
$100
Windshield Washer Tank
No issues. Once again, this would be great for someone wanting to send off to be modded for Meth.
$25
30 Spline Yoke
It’s in great condition. I just had to use a 31 spline for my TR-6060.
$50
04 Stock Power Steering Cooler
No leaks.
$50
Battery Tray
Minor surface rust, otherwise it’s perfect.
$25
Stock STB
It has two small chips on each bend near the center.
$25
Stock 04 Driveshaft
The shaft and carrier is in great condition, but the couplers are showing signs of wear.
$75
Center Dash Piece
It’s in great condition with no broken tabs.
$40
04 Front Brakes
No Issues. It would be a great set for someone wanting to powder coat them and have no down time.
$Sold
Old May 13, 2011 | 09:59 PM
RacerBill's Avatar
04 Rear Brakes
$Sold
Miscellaneous stuff…
Crash bar, 04 radiator shields, ECU holder, ECU Heat Shield, Top gas tank cover, EVAP line, Stock front struts, Trunk cover, etc.
$50 (had to list a price, but I would most likely just give this stuff away, except for the trunk cover…)
05/06 Fan Shroud w/04 Fans/Connectors
The top of the shroud is trimmed to fit a 1” shorter radiator.
Fans are sold, but the shroud still for sale ($50)
DSS 2-piece Driveshaft Chromoly/Aluminum (Lists for $1200, I believe)
You would just need a yoke to fit your application. I just put this in, but in order to meet NHRA rules, I must have a 1-piece with a DS loop.
$800
H/C LS1 - 70k Miles
There are ABSOLUTELY no issues with this motor. I only swapped this one out because I went with a stroker. All the specifics on the motor are in the link in my sig. The dyno graph is before I did a FAST 102/102. I have been debating on keeping it to put in a Factory Five GTM, but I would entertain selling it instead of it just sitting here until I get “a round tuit”.
I would swap it into another GTO for $5k, and I would probably sell outright for $4500.
Drag Setup - GTO Spares w/stock tires & Corvette Reps (17x9.5) with M/T 275/40 DRs
I have had this setup for almost a year now, and I don’t have a single complaint with it. I have put maybe 150mi on them on the street and quite a few passes. I am only looking to sell to clear up some space for my new drag setup. Rear tires have a little life left in them but won’t last long if you do big, nasty burnouts.
$500
Well, that’s it for now... Let me know if you need any detailed pics.
Thanks!
Old May 14, 2011 | 01:59 AM
03impala9c1's Avatar
ygpm on maf
Old May 14, 2011 | 08:15 PM
RacerBill's Avatar
Bump!
Old May 14, 2011 | 09:20 PM
UnVMySS's Avatar
Will the engine covers fit 2000 camaro ss? If so ill pick them up!!Dibs!
Old May 14, 2011 | 09:46 PM
RacerBill's Avatar
I have no idea... Sorry.
Old May 14, 2011 | 10:04 PM
Tamatt27's Avatar
Do you have access to the tranny the shifter came out of? I'll be putting the shifter on an F-Body T56 and will need the cup that the shifter ball fits into.
Old May 14, 2011 | 10:08 PM
RacerBill's Avatar
No, I sure don't. I have a TR-6060 now. I believe the shifter cups can be purchased a few different places though.
Old May 15, 2011 | 09:47 AM
Tamatt27's Avatar
How much is shipping on the shifter to 78617?
Old May 15, 2011 | 08:08 PM
RacerBill's Avatar
I'll check on shipping tomorrow. Thanks
Old May 18, 2011 | 05:52 AM
RacerBill's Avatar
Shifter sold...
Prices are definitely OBO... keep'em reasonable though
Old May 18, 2011 | 11:26 AM
00firehawk's Avatar
PM sent
Old May 19, 2011 | 03:58 PM
RacerBill's Avatar
Bump!!!
Headed to Mooresville, NC tomorrow if anyone wants any parts and can meet up...
Old May 19, 2011 | 11:41 PM
camaroboricua's Avatar
how much for the Maf shipped? do you know if it will work on a 2000?
Old May 20, 2011 | 12:11 AM
So.jerZ-28's Avatar
what is the backspacing on the front & rear rims w/tires?
Old May 20, 2011 | 05:20 AM
RacerBill's Avatar
PM Sent
I have no idea on the fronts, but the rears have a 52mm offset.
Old May 20, 2011 | 03:18 PM
70chevellebu's Avatar
pm sent
Old May 20, 2011 | 04:02 PM
RacerBill's Avatar
Originally Posted by 70chevellebu
pm sent
Returned!
Old May 21, 2011 | 08:17 AM
RacerBill's Avatar
Headed to the post office in a few... Bump!
