UMI NEW tubular A-Arms (black), NEW Ron Davis aluminum radiator, NEW Scorpion rockers
Category: Audio/Video/Electronics
Price: $450
Part Fits: 93-02 Chevrolet Camaro
Location (State): MO
Item Condition: Brand New
LS Engine?: Fits LS Engine
Starting at: $547.99
UMI Performance tubular A-Arms are designed to outperform the stock setup whether it’s at the race track or an added improvement to your daily driver; they've been tested and improved to handle both applications. These A-Arms are designed to add front end rigidity, increased strength and to eliminate flex found with stock A-Arms. A-Arms are built using strong DOM steel tubing, 3/16” thick CNC machined ball joint mounts. They are supplied with grease-able Energy Suspension polyurethane bushings on the upper control arms and ¾”chrome moly rod ends on the lower A-arms. The lower A-arms feature adjustment if needed while the upper A-arms are non-adjustable and feature grease-able polyurethane bushings for ride comfort. The upper A-Arms also feature an improved ball joint angle for lowered vehicles but work fine on a non-lowered vehicle. The lower A-arms feature new ball joints installed while the upper A-arms re-use the factory ball joint or new factory style ball joint.
When do you choose adjustable upper A-Arms? A question we get asked a lot is when do I need adjustable upper A-Arms for my application? Adjustable A-Arms allow the operator to make front end changes such as improved caster and camber. These changes are very crucial when high handling such as autocross or road race is present. If caster or camber adjustments are desired they must be made by a professional alignment center. This procedure may take time and involve extra cost. If your vehicle is exposed to street driving and/or drag racing these upper A-Arms are the perfect set-up for you.
Features:
- Manufactured from 1.250” mild steel tubing
- All tubing precision bent and CNC machined
- New lower ball joints installed
- ¾” high quality chrome moly Teflon lined rod ends
- Grease-able Energy Suspension polyurethane bushings
- Brilliant, Durable and long lasting powder coat
- Uses OEM Hardware
Application:
1993 - 2002 Chevrolet Camaro
1993 - 2002 Pontiac Firebird
SOLD
Ron Davis aluminum radiator for 98-02 F-Body (NEW) no oil cooler, set up for auto (external cooler), or manual trans vehicle. Direct drop in. Set up for factory fan shrouds. VERY nice piece. No wait, buy it now.
SOLD
NEW Scorpion LS1 rocker arms 1.7 ratio 300.00
Buyer pays shipping charges and Paypal fees if used.
