Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
shop full of 93-02 camaro firebird trans am and formula parts
Old Jun 7, 2011 | 03:17 PM
STS95T/A's Avatar
Default shop full of 93-02 camaro firebird trans am and formula parts
Category: Drivetrain
Price: $20
Location (State): TX
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
I have a shop full of parts that i pulled off of 93-02 camaro’s firebird’s and trans am’s
Here is a list of everything that i can think of
Hatch shocks-$20 pair
95-99 firebird / trans am drivers airbag-$30
93-99 camaro drivers airbag-$30
93-99 passenger airbag-$20
Tan leather seats drivers has a tear-$100 pickup only
Charcoal gray leather seats drivers has a tear-$100 pickup only
Tan leather trans am door panles-$40 pair pick up only
Tan leather Camaro door panles-$40 pair pickup only
Charcoal cloth firebird door panles-$40 pair pickup only
Trans am hatch with high rise spoiler in green, maroon, and white-$200 each pickup only
93-95 dot matrix t-tops drivers and passengers-$70 each
96-99 tinted t-tops drivers and passenger-$70 each
98-02 non-ram air trans am hood in green-$50 pickup only
93-97 non-ram air trans am hood in white and red- $40 each pickup only
Firebird formula hatch in teal, red, and silver-$40 each pickup only
Camaro Z28 hatch in red, teal, silver, white-$40 each pickup only
93-97 camaro headlight bar with headlights-$60
93-02 camaro tail light center panel in green, teal, white, and red-$30 each
94-96 trans am gauge cluster-$30
94-97 LT1 throttle body-$30
93-94 LT1 timing cover-$25
96-97 LT1 timing cover with crank sensor-$80
Vented 95-97 opti-$60
96-97 crank hub/balancer-$25
Reluctor wheel 96-97 LT1-$10
93-94 LT1 starter-$50
95-97 LT1 starter-$50
93 LT1 alternator-$30
94-97 alternator-$40
93-95 ICM/coil assembly-$20
96-97 ICM/coil assembly-$20
LT1 water pump-$25
LT1 idler pulley assembly-$10
LT1 factory stamped rockers with studs-$20 set of 16
LT1 valve covers-$20 pair
96 LT1 T56 PCM-$60
LT1 motor mounts-$30 set
LT1 power steering rack-$20 pickup only
LS1 power steering rack $50 pickup only
93-97 LT1 Power steering pump-$20
93-97 power steering fluid reservoir-$15
93-97 crank-$40 pickup only
93 intake manifold-$40
94-97 intake manifold-$50
LT1 cam retainer with bolts-$10
LT1 lifters-$30 set of 16
LT1 lifter holders (bones)-$10 set of 8
Lt1 lifter holder retainer (spider)-$10 with bolts
LT1 push rods-$10 set of 16
94-97 fuel rails-$30
94-97 LT1 plastic fuel lines (to fuel rails)-$25
93 plastic fuel lines (to fuel rails)-$25
LT1 fuel sending unit with good pump-$60
LT1 metal fuel tank-$20
98 LS1 fuel sending unit with good pump-$60
LS1 timing cover-$30
LS1 cam retainer-$10 with bolts
98 LS1 lifters-$40 set of 16
98 LS1 exhaust manifolds-$30 pair
LS1 non-traction control throttle cable-$20
Ls1 steering linkage-$15
Lt1 steering linkage-$15
94-97 LT1 PCM holder-$10
93 LT1 PCM holder-$10
93-97 rear disc brake backing plates-$40 pair
93-97 rear disc brake calipers-$25 each
93-97 disc brake e-brake cables-$25 set of 3
94-02 4l60e shifter linkage assembly with both cables-$50
LS1 factory roller rockers with stands-$50 for all 16
Automatic pedal assembly-$25
Manual pedal assembly-$50
LS1 4l60e tranny crossmember-$25
LT1 4l60e tranny crossmember-$20
LT1 4l60e flex plate-$20
LS1 flex plate-$30
LS1 MAF sensor with screen-$40
LT1 MAF sensor with screen-$40
93-96 dual horn assembly-$20
97-02 dual horn assembly-$20
Lt1 brake master cylinder-$10
LS1 brake master cylinder-$20
Lt1 3 channel ABS control module- $20
LS1 3 channel ABS control module-$20
LS1 automatic radiator-$30
LT1 automatic radiator-$30
LT1 dual fan assembly-$70
LT1 ac condenser-$20
LS1 ac condenser-$20
LS1 stock plug wires-$10 set of 8
93-95 LT1 exhaust manifolds-$25 pair
96-97 LT1 exhaust manifolds-$25 pair
99-00 LS1 exhaust manifolds-$25 pair
LT1 radiator support-$20
10 bolt 3 channel non-traction control axle half shaft-$25
3 channel abs sensor-$10
93-97 3 channel abs sensor harness-$10
98-02 3 channel abs sensor harness-$10
LT1 clutch alignment tool-$10
And many other parts
please pm me if interested in anything
all parts are located in mansfield tx 76063
thanks
robbie
Old Jun 7, 2011 | 04:02 PM
PewterSS#4302's Avatar
pics of t-tops to jason413@catt.com any scratches?
Old Jun 8, 2011 | 12:03 PM
STS95T/A's Avatar
pics sent
thanks
robbie
Old Jun 8, 2011 | 01:42 PM
TIIMuch's Avatar
Hey Rob
I need the following:
-LT1 MAF
-LT1 rad support(we're talking about the black plastic cap/cover on top right?)
-Manual pedal assembly
PM me a price total, shipped to 98295, and your PayPal addy
Old Jun 8, 2011 | 07:35 PM
Dabom75's Avatar
Do any of the tail panels have emblems on them?
Old Jun 9, 2011 | 01:41 PM
STS95T/A's Avatar
several of the tail light panels have Z28 emblems on them
PM sent on the LT1 parts
thanks
robbie
Old Jun 22, 2011 | 09:43 PM
STS95T/A's Avatar
to the top
Old Jun 23, 2011 | 09:18 AM
nitrovette's Avatar
Sent pm on ls1 maf sensor
Old Jun 23, 2011 | 05:14 PM
STS95T/A's Avatar
to the top
thanks
robbie
Old Jun 23, 2011 | 05:33 PM
tnmotown's Avatar
PM me if you have a IAT sensor and the throttle cable bracket. Thanks!
Old Jun 27, 2011 | 11:38 AM
STS95T/A's Avatar
sorry but i don't have either
to the top
thanks
robbie
Old Jul 3, 2011 | 02:51 PM
STS95T/A's Avatar
to the top
thanks
robbie
Old Jul 4, 2011 | 02:27 PM
Mighty Whitey's Avatar
98-02 firebird/trans am driver fender and headlight?
Old Jul 5, 2011 | 07:12 PM
STS95T/A's Avatar
thanks
robbie
Old Jul 7, 2011 | 06:43 PM
STS95T/A's Avatar
all pm's returned
thanks
robbie
Old Jul 8, 2011 | 06:59 PM
lt4388stroker's Avatar
do you have ls1 coil harness for both sides
Old Jul 8, 2011 | 07:32 PM
STS95T/A's Avatar
sorry no coil harnesses right now
thanks
robbie
Old Jul 8, 2011 | 07:46 PM
faster_n_you98's Avatar
Do you have an oil cap/pcv cap off a driver side valve cover from 97-98 ls1? Its gm part number 12557672. Thanks!
Old Jul 10, 2011 | 11:17 PM
STS95T/A's Avatar
sorry but i don't have one
thanks
robbie
Old Jul 21, 2011 | 04:24 PM
carguyshu's Avatar
do either of the seats have a MANUAL drivers side seat track? if so, is it the kind that has tilt feature and do they have the inflatable side bolsters? I'm interested just in the drivers side seat track assembly if this is the case. let me know
