Shop Spring Cleaning part 2
Category: Drivetrain
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): IL
Item Condition: Used
LS Engine?: Fits LS Engine
have many odds and ends, Some have prices, others don't. make me an offer either way, I'm not sitting on gold.
All prices that are listed are for the part, buyer pays shipping, obviously if your buying more than one part I would combine everything.
Pm me if interested, open to possible trades.But it would be faster to call or text me at 1-815-277-6846, ALL PICS CAN BE EMAILED OR TEXT, ASK AND I'LL GET PICS TO YOU ASAP.
and here it goes..
-stock T56 trans crossmember
-Stock auto trans crossmember
-Door Speakers and factory amp out of my 2001 WS6
-LQ4 Stock intake with rails and injectors-broken vacume nipple, ask for pics
-Stock cruise control module with bracket and cable - 3 Channel car
-Stock floor mats, T56 car, heel hole in drivers, rest are mint.
-Air lift air 1000 spring kit, part #60792 never used, box is beat up
-misc door speaker grills out of 01 T/A
-Stock Lower control arms
-Stock panhard rod
-factory tar paper shield that goes underneath frame and around the stock swaybar, not torn
-Stock ABS module, 3 channel non traction control car.
-Factory exhaust crossmember
-Stock ash tray and change/coin holder
-2 sets of factory horns
-Stock brake booster and master cylinder with lines to abs control module
-Entire heater box unit, no broken tabs or screw mounts from removal
-LS1 front cover-painted black
-Stock 6.0 L pushrods, 13k miles
-Smooth Bellows with holes for nitrous bungs
-Starter dust shield
-Used LS1 oil pump, 35k miles
-LS2 oil pump out of 2006 GTO, motor blew after a unsafe 300 hit of nitrous, pump is fine, not trying to hide anything thats all.
-Lou's Short Stick with bolts- $30
-MBA billet aluminum shift ball, Black, say "WS6", no tail, smaller dia. I believe-$75
-Stock LS1 brown stripe valvesprings, 35k
-Stock hurst shift handle with the rubber isolator
-Stock valvespring retainers
-Stock rocker arm stands, 2 sets
-LS2 GTO aluminum motor mounts with stands
-stock 99 Z28 upper air box with nitrous ports in it.
-Fast throttle body box, what they ship it to you in, gotta be good for something, I just havnt found it yet...
-All the factory heat shields from under a 98-02 F body
-Stock air bag control module
-stock coolant over flow bottle/ battery tie down.
-Stock F body LS1 radiator, M6 car
-Rear impact absorber from T/A
-Ebony T/A Gauge cluster plastic surround piece
-Used LS7 Fidanza Aluminum Flywheel, burned up, new insert is $35.00 from Fidanza-$300
-NEW LS1/LS6 style Clutch Chrome Moly Flywheel, still in box-$200
-6.0L truck water pump, 13k miles
-Procharger Intercooler, 3" wide, 3" Dia. tubes in/out, 2 core, barely used, mounting tabs welded on-$500
-Stainless 3" exhaust cutouts
-Entire 2001 LS1 fuel lines, from tank to rails, I dont know about shipping this...
-Stock Fuel Pump and Sending unit, 60k miles
-Stock K member
-Stock front control arms, upper n lower
-Power steering rack
-TH350 Trans, good running used trans, fluid is pink-$200
-Two Chrome Camaro SS/ZR1 Rims, Factory Rims, not repo's Good to Ok condition
-Ebony rear cargo area covers, only one left, hinge pin plastic cracked on drivers side.
-Ebony T-Top holders
-Stock 2001 T-56 Torque arm
-Black "Camaro" front Bumper insert
-2005 C6 Corvette upper radiator mount
All prices are OBO, make me an offer, most dont have a price because, well I'm not sure what it's worth, make me an offer. open to trades.
Chris
1-815-277-6846
call/text if you call and no answer, please leave a voicemail, I will get back to you.
