Help Calculating VE
Old 04-03-2004, 08:11 PM
screamn03's Avatar
Question Help Calculating VE
I've tried using the different equations found in this thread https://ls1tech.com/forums/pcm-diagnostics-tuning/99870-fuel-trim-ve.html and couldn't get them to work . I need a equation that I can use to find VE based on MAF, MAP, RPM, IAT, and anything else I need. I keep getting numbers way to big or way to small. Any help would be great.
Equations I've Tried
Determine Theoretical Flow:
T Flow = ((RPM * (Engine Size ft3))/2
Convert to Mass Flow:
T Mass = T Flow * (MAP Kpa / 101.3) * .0780
Determine Actual Volumetric Efficiency:
VE Actual = (MAF lb/min) / T Mass
Determine LS1 Edit Volumetric Efficiency:
VE Edit = VE Actual * 3000
VE = MAFFlow * (Temp + 273.15) / (Displacement * RPM * MAP) * 212544
g/sec *c cyl cu/in kpa
And this confused me
BTW: I'm using HP Tuners so I don't believe that I have to solve for VE Edit because in HP Tuners it is just asking for a percent.
http://www.hptuners.com/forum/YaBB.p...num=1080973033
Old 04-04-2004, 12:46 AM
deezel's Avatar
I have used this one and got reasonable numbers...
%VE = (MAF * (IAT + 273.15) / (DISPL * RPM * MAP)) * 212544
Old 04-04-2004, 03:50 PM
screamn03's Avatar
Just to make sure I'm using the correct unit:
MAF=grams/second
IAT=*C
DISP=One Cylinder in CU/IN
MAP=KPA
Is this correct? I used these units and got something that looked reasonable but I just want to make sure. Thanks
Old 04-04-2004, 07:43 PM
screamn03's Avatar
Maybe it's just me but I can't seem to get any good numbers using that equation or any of these for that matter.
Example
IDLE
MAF=6.89 g/sec
IAT=40.56 *c
RPM=807
MAP=37.92 kpa
%VE=(6.89*(40.56+273.15)/(43.25*807*37.92))*212544
%VE=(6.89*(313.15)/(1323512.28)*212544
%VE=(2157.6035)/(1323512.28)*212544
%VE=.00163021*212544
%VE=346.4914419
Old 04-04-2004, 08:19 PM
screamn03's Avatar
http://www.installuniversity.com/ins...n_9.012000.htm
This was helpful.
Old 04-04-2004, 08:43 PM
deezel's Avatar
In the equation you're using, you should use the displacement of the entire engine in cu.in. (346 ci for a 5.7L)...
Old 04-04-2004, 10:05 PM
screamn03's Avatar
I did my calculations again using total engine displacment and ended up with 4.855550213E15 or 4.855550213000000.00
Old 04-06-2004, 09:43 AM
deezel's Avatar
Example
IDLE
MAF=6.89 g/sec
IAT=40.56 *c
RPM=807
MAP=37.92 kpa
Using your data I get this:
%VE = (6.89 * (313.71))/(346 * 807 * 37.92))*212544
...... = (2161.46)*(212544)/(1.059e+07)
...... = 43.38%
Old 04-06-2004, 01:20 PM
screamn03's Avatar
Thanks Bro,
Now I see my error .
I was doing this...
...... = ((2161.46)*(1.059e+07))*(212544)
...... = wrong answer
When I should have done it this way...
...... = 43.38%
I see my error now. Thanks for the reply and helping me out. I think I'm gonna have to enroll in another math class next semester .
Old 04-06-2004, 01:37 PM
deezel's Avatar
You're welcome.
Those spreadsheet formulas can get pretty messy with all the parentheses to keep straight. Good luck with the tuning.
