Alternator bracket template
Old 04-09-2004, 04:04 PM
Conversion master
70 LS1's Avatar
Default Alternator bracket template
Here is my design for the alternator only bracket I am using. This mounts the alternator high on the drivers side. Mine is 1/8" aluminum, but if I had it to do over, I would use 1/4". I can't seem to post them here, so email me for a copy. The drawing is in ACAD 2000 .dwg and .dxf formats.
Here is a picture of the bracket on my car. The drawings are a cleaned up version of the prototype.
Old 04-09-2004, 04:50 PM
Conversion master
70 LS1's Avatar
One thing I forgot to mention. I am using the stock F-body alternator bracket just for the idler pulley. You could go without it, but the belt wrap on the crank pulley would be less.
Old 04-10-2004, 12:17 AM
HotRod68Camaro's Avatar
I would like more info MetalBassist16@hotmail.com
THanks
Kyle
Old 04-12-2004, 04:15 PM
Coolvet's Avatar
Nice job....but does the alternator have any lateral movement with that bracket? It doesn't look rigid enough to stop any forward/rearward movement. Why didn't you use the C5 Corvette OEM bracket?
Old 04-12-2004, 04:48 PM
Conversion master
70 LS1's Avatar
The bracket works great. I made the bracket non-adjustable due to the belt tensioner. I have had no flex problems in the last 2 years it has been on the car either. The bottom bolt of the alternator is attached to both the front and rear brackets and creates a surprisingly sturdy piece. Like I said above, I would use 1/4" if I made another one and I would use the same bracket for the front and rear.
I chose to make my own instead of use the C5 version for a few reasons. One was cost. It was much cheaper to make one than buy a new C5 bracket. And the other is I didn't want to change my crank pulley and belt tensioner to the C5 version. And you have to remember that when I did my conversion, there were not a lot of other people doing it and parts were not as readily available as they are today.
Old 04-14-2004, 07:47 PM
DaleMX's Avatar
Looks great!
Old 04-15-2004, 12:10 PM
Scooter70's Avatar
Here are some CATIA drawings of the plate and the complete assembly. I can send 3D data if anyone can read it and wants it. The dimensions of the holes are what's really important. The edges of the part can be whatever looks best, as long as it doesn't hit anything.
Attached Thumbnails Alternator bracket template-ls1_alternator_bracket_dims.jpg   Alternator bracket template-ls1_alternator_bracket1.jpg
Old 05-02-2004, 12:17 AM
MASS seller approved
Time2Kill's Avatar
Can you send me the 3d data?
timsova@triton.net
Tim
Old 05-02-2004, 11:21 AM
Scooter70's Avatar
Catia V5 (R11) or IGES? I have it at work so I can do it tomorrow.
-Matt
Old 05-02-2004, 11:47 AM
Time2Kill's Avatar
IGES, but if you can send them both that would be cool too.
Old 08-05-2012, 09:00 PM
BIGRLZ's Avatar
Can you please send me a 3D copy because I'm putting a LS1 into my 79 Firebird and I have to move the Alternator so it could fit under the hood.
richard.lazard@us.army.mil
Thank You
Richard
Old 08-05-2012, 11:28 PM
oldngray's Avatar
Default blueprint
Would like to have a copy if possible
mdjkl@montanaport.net
Old 08-06-2012, 05:22 AM
Killer66's Avatar
Looks awsome, how about powersteering pump?
nytramkd@yahoo.com
Old 08-06-2012, 07:37 AM
74modified's Avatar
Guys, this is an old thread this guy:
70 LS1
Conversion master
Last Activity: 01-15-2011 12:28 PM
You may not hear anything from him
Old 03-09-2013, 01:26 PM
radhof's Avatar
Hello
Would like to have a copy if possible!?!
Thanks info@radhofgarage.ch
Greatings fom switzerland
Old 01-23-2020, 09:09 PM
Ken Tooker's Avatar
Default Cad drawing
Can can you email a copy in CAD to me?
thanks
ktooker@energexcp.com
Old 01-23-2020, 10:46 PM
Received 3,027 Likes on 2,357 Posts
70 LS1 hasn't been here for over 8 years.
NCDEERE (01-24-2020)
Quick Reply: Alternator bracket template
