Titanium Control Arms
Old Apr 26, 2004 | 10:15 AM
technical's Avatar
Default Titanium Control Arms
Anyone know anything about these control arms... http://www.paceparts.com/product.asp...1=310&3=191501
I searched the forums, but no mention.
Are they worth the $250?
Old Apr 26, 2004 | 10:31 AM
Damage Inc.'s Avatar
Sweet Cheeks
7LBS, I'd say it's worth it if you're looking for the lightest possible LCA. Billingsley makes the lightest chromoly set I know of @ 4.5lbs each. It's up to you, but I'd take them for a ride.
Old Apr 26, 2004 | 10:42 AM
Scalpel's Avatar
If only they had rod ends.
Old Apr 26, 2004 | 11:06 AM
technical's Avatar
How much for the Billingsley parts? And where do I get 'em?
Old Apr 26, 2004 | 03:26 PM
Sweet Cheeks
Actually, I have a set of Billingsleys still in the boxes with dual rod ends. They're red and I have a double adj. panhard from them to match. They sent me the wrong color. If you want them I can have Larry from Speed Inc. hook you up. He's the one I got them from. They're super light, but I don't need dual adjs. Let me know or pm me.
Old Apr 26, 2004 | 08:10 PM
2w0s060's Avatar
My Tubular mild steel LCAs only weigh 8lbs, 7lbs doesnt sound very light compared to that.
Also, there not painted. Not sure on the affects of titiaum but I am sure in some way or another they might oxide
Old Apr 26, 2004 | 08:38 PM
John95Z28's Avatar
Originally Posted by 2w0s060
Also, they're not painted. Not sure on the affects of titiaum but I am sure in some way or another they might oxide
Titanium does oxidize, but not in the sense of forming rust (iron oxide) and eventually falling apart. They could be left unfinished, but would have looked much nicer if they were powdercoated.
Waste of money IMO. I'd just get a set of 1LE control arms, unless you're into heavy duty racing.
Old Apr 27, 2004 | 08:46 AM
2w0s060's Avatar
Thats what I meant, I figured over time something might happen to them.
Also agreed, overpriced for what you get.
Old Apr 27, 2004 | 01:42 PM
Trojan T/A's Avatar
The lightest would be the Madman design that BADZ sells. They are tubular aluminum and they weigh around 5lbs for both. They have rod ends too. They cost a lot less than those Ti pieces too.
Old Apr 27, 2004 | 02:32 PM
John95Z28's Avatar
I wonder if anybody makes subframe connectors out of Ti? They'd be good and stiff, since Titanium is twice as strong as steel, for half the weight. Probably not worth the exorbitant cost - $1000(?)
Old Apr 27, 2004 | 03:50 PM
2w0s060's Avatar
I dont think they are tubular alum LCAs are they??
Prob solid 6061 drilled and tapped for rod ends.
Old Apr 27, 2004 | 07:07 PM
BADZ's Avatar
Yes, my pieces are 4.9 lbs per set and with the phr its just over 10lbs and no one can match our prices!!!!! These are solid billet T6061 double adj using a right hand and left hand threaded rod ends so you can adjust while on the car!!!! MINE ARE THE LIGHTEST
Old Apr 27, 2004 | 07:41 PM
ta12sec's Avatar
Badz are the **** Some of the best money i ever spent on my car were the lcas from him. Hey badz can you get a hook up on a torque arm too?
Old Apr 27, 2004 | 10:04 PM
98_1LE's Avatar
I think the LG aluminum tubular LCA's with rod ends would be the lightest. Lou doesn't have them on his site, so you have to call them. I have had them on my car for 16K+ miles with no problems.
But like CANNIBAL said, if they only had rod ends.
Old Apr 28, 2004 | 06:56 AM
BADZ's Avatar
Sorry, mine are still the lightest and with rod ends!!
Old Apr 28, 2004 | 07:47 AM
technical's Avatar
I'm more into road racing and autocross, but I think I have an unhealthy addiction to Ti
From what everyone has said, it seems that these arms don't gain you much. Especially if cheaper steel units are just as light. I don't want adjustable arms either. So I guess 1LE LCA's will do fine.
Old Apr 28, 2004 | 11:20 AM
2w0s060's Avatar
Theres some companys out there that make some nice tubular control arms with poly bush. for under a $100, very comparable to top notch brands. I have seen them and ran them
Old Apr 28, 2004 | 11:21 AM
2w0s060's Avatar
Whats up with the purple Rod ends
Old Apr 28, 2004 | 11:34 AM
technical's Avatar
Under $100 sounds very tempting. To which companies are you refering?
Old Apr 28, 2004 | 05:50 PM
BADZ's Avatar
One's that are probley out of business by now!!!
