Mobil 1
Old 05-16-2004, 12:54 AM
KillaP's Avatar
Default Mobil 1
I just switched over to Mobil 1, and heard that I have to change it again after the first 500 miles and then start the normal 3000 cycle. Is this true? Thanks fellas
Old 05-16-2004, 01:17 AM
02WS6#519's Avatar
I don't think so.
Old 05-16-2004, 07:31 AM
crainholio's Avatar
No way. 4500 mi is the minimum street mileage I'd run Mobil1 between changes, and based on used oil analysis data on bobistheoilguy.com you could go much longer than that.
I'd run that first fill to 3000-4500 miles to let it do it's job of cleaning...it will probably get good 'n black quickly, that's fine. The longer you let this fill run, the less cleaning work the 2nd fill has to do.
I regard oil changes as somewhat traumatic to the engine...first few seconds of initial startup it has no oil pressure. Manufacturing debris from the filter has to make one circulation before it makes its way to the business side of the filtration media. I therefore try to stretch my oil life as much as practical.
Old 05-16-2004, 09:44 AM
Racehead's Avatar
Do whatever feels right to you. Change it at 5 miles, 500 miles, or 5000 miles. It's not going to make any differance.
Old 05-16-2004, 10:35 AM
'01PEWTERTA's Avatar
Old 05-16-2004, 10:48 AM
Racehead's Avatar
Originally Posted by '01PEWTERTA
OK for those of you that couldn't follow along
Within 5 miles your oil has recirculated 100's of times so when switching from dyno oil to synth you can count on the dyno oil having been washed out of every crevice inside your engine within this time. So if your concern is to get the dyno oil out and have only synthetic in then now would be as good of a time to change it as any.
Synthetic oil will work just fine with a little dyno oil still in it however, so you could run it 500 miles and then change it out, or go ahead and use your regular oil change interval of 3000, 5000, or even longer to change it out if you don't want to just throw $35 worth of good oil away as you would be doing with a 5 mi. change out.
In other words do what feels right to YOU. It's not going to matter as far as engine longevity, the only differance is to the wallet. I just plumbed in an oil cooler to my LS1 and changed the oil within 20 miles. Costed me $35 or so, but I wanted to make sure that any debris from the freshly made up 15' or so of oil lines was washed out.
Old 05-16-2004, 02:19 PM
KillaP's Avatar
ok, cool! Thanks for the info guys.
