Drag Racing Tech
15w-50 oil
Old 05-17-2004, 07:31 PM
john shea's Avatar
Default 15w-50 oil
hello
I have a 99 firebird formula that I drag race every weekend.Is mobil
15w-50 oil too heavy to run on a street/strip car?
thanks for any reply.
sincerely
formula
Old 05-17-2004, 07:39 PM
SUX2BU's Avatar
i un Valvoline 20-50 in my daily driver. no problems here.
Old 05-17-2004, 11:14 PM
GIZMO's Avatar
I did a back to back test in my LT1 Formula when I was running IHRA Pure Stock. There was a 0.1 drop in ET in the 1/8th when I switched from conventional 20-50 to 0-30 synthetic oil. Just something to think about if you are looking for cheap HP.
Daren
Old 05-18-2004, 03:57 PM
BadAndy's Avatar
Damn, you dropped a whole tenth from an oil change? Do you think the gain was more from the viscosity switch or from the dino to synthetic switch?
Old 05-18-2004, 06:40 PM
BLK02WS6's Avatar
Daren
That is true for a short usage, but you don't wanna run it in a daily driver! The 0-30 will not hold up to daily usage - I just read a test on that recently. Those who use the very thin racing oils change their oil VERY frequently (like after each trip to the track).
I use 10W30 Amsoil and have seen around a half tenth from it (over conventional racing oil). It holds up very good in a daily driven/strip car. Running oil that is too thick just robs horsepower cause your engine has to pump the thick oil.
Old 05-19-2004, 08:15 PM
GIZMO's Avatar
[QUOTE=BLK02WS6]That is true for a short usage, but you don't wanna run it in a daily driver! The 0-30 will not hold up to daily usage - I just read a test on that recently. Those who use the very thin racing oils change their oil VERY frequently (like after each trip to the track).
I run the Mobil-1 0-30 about thirty passes betwean changes without any bearing issues. The oils that you need to be really careful of are in the 0-10 range and are, in my opinion, only good for a couple of passes.
The main reasons that I run light weight synthetics are;
1. Superior oil film to regular oil.
2. Less windage.
3. Faster drain back.
I never run more than four quarts in my LT1 Stocker motors which go thru the traps at 7200 rpm. As a side note my 2003 Mustang had 5-20 oil from the factory.
Best Regards,
Daren
Old 05-19-2004, 09:08 PM
boomcase's Avatar
Dam in my 99 TA book it recommends 5-30 for the LS1 and if you are in a very hot climate 10-30 and in bold print it says do not run 20-50 .
