*** Cartek 427 Is In !!! 575 Rwhp 528 Rwtq***
as most of you know i have been building a 427 for my Z06
here are the specs
4.0 stroke
4.125 bore
HYD roller cam
CARTEK ls6 stage 5 heads
93 octane pump gas
steel flywheel....may switch to lighter one later...
3.90 gears
KOOKS 1 7/8 headers
VARA-RAM
FAST intake and 90 mill tb
575 rwhp 528 rwtq dyno with full exhaust and all belts on and with pump gas!
as you guys know dyno #s are one thing
track #s are a whole other story.....so i plan to take this new monster to the track!!!!
my goal is 9's N/A with a 6 SPEED
thanks to CARTEK for building me yet another beast !!!
here are the specs
4.0 stroke
4.125 bore
HYD roller cam
93 octane pump gas
3.90 gears
KOOKS 1 7/8 headers
VARA-RAM
thanks guys
julio will post the dyno graph soon
when i started with the build up my only requirement was
93-94 octane and street-friendly
i personally do not know the cam specs
i do know the comp. ratio to be 11.2 -- 1
yes i still have the 6 speed tranny and hope it will not expode!!!
we are going to try a few other things to help out those #s
like....boost a pump
when we tried to take the belt off on the dyno the fuel pressure drops 20lbs....
we also want to go back to the light weight flywheel
right now we have the stock one in...
and a few other changes which i cant speak about....
as always i plan to back it up.....if i can hook it up @ the track
only
will tell
only
will tell
