X-Pipe Experience
For those of you living in the DFW area B&B does great exhaust work and they are located in Hurst off of Bedford Euless Rd. I figured it would be much louder and to be honest I can hardly tell it is installed (noise). Even at WOT it is a slight growl of a difference and perfect mod to keep things quiet like a Caddy. What is noticable is dropping the hammer . I can give confirmation that it is putting 15-20 to the ground easily. This is a must do mod for any V owner.
Here is a good article explaining what it does;
http://www.vetteweb.com/tech/0307vet_xpipe/
BTW it doesn't replace the cats.
Originally Posted by wildwhl
How does the xpipe make the car sound from the outside, any louder?
If so, soundclip please!
Clean install, thanks for the pics.
Wildwhl
Wildwhl
Maybe one of the others guys could help out with that?
Originally Posted by globed70
I can imagine that there are some ponies to be gained... but without an actual before and after dyno the question is HOW MUCH. It is possible that much of the HP to be claimed by exhaust manufacturers will come from elimination of the resonator... so how much HP on the dyno is nice to know. Not doubting you, but if you look at the performance difference from 15hp, the buttometer doesn't mean jack.
https://ls1tech.com/forums/showthrea...ghlight=x-pipe
Scroll down to the post from Nineball.
My comments were not assumptions so if they came across that way I apologize. Exhaust restrictions on the V's is no secret and the gain from the x-pipe has been proved.
