BMR GTO - 11.23 Video
LS1Tech Premium Sponsor
We took the project car to the track this weekend with an optimistic high 10 second goal in mind. We upgraded our converter to 3500 stall speed and were planning on testing our new progressive NOS controller. It was 74% humidity and 94 degrees out. The track temperature was 114 degrees with no wind whatsoever. Our best pass to date had been an 11.35@119mph but that was back in February with 60 degree weather. Regaurdless of the heat, we widdled our way down from 11.85 to 11.23 just by varying launch rpm and NOS activation times. It was looking like we could have made our goal but the posi went out on the next run and the next 3 passes the right rear just went up in smoke.
Anyway, here is the video of our quickest pass - VIDEO
Even though we took about 80 lbs. out of the car, we added much more with the roll bar, subframe connectors, and two 25 lb. nitrous bottles. With driver, the car weighs in at 4085 lbs!
Originally Posted by Rob
Nice clean looking pass. Too bad about the rear. How many hard launches did the rear take before it went?
We have run a 1.60 sixty foot time but we are pushing it with the stock CV axles. Within the next few weeks we will have custom axles available that will survive up to 800HP. They use billet CV joints and larger diameter axles made from 300M material, the strongest axle material made. Pricing is not yet available but should be somewhere around $1,000 for the pair.
Originally Posted by GTA91
Hell yeah! Can you list ALL the mods?
Nice!
What does the car run on motor with that converter?
Originally Posted by jruss
what kind of rpm are you launching at ?
How much rear wheel hp are you pushing to run a 11.23 ?
With that shot you are running is that on stock fuel pump and injectors ?
Are those stock rims in that pic in your sig ?
The wheels in the sig are I-Forged, 18x8F and 19x10R
Originally Posted by Jammin Joel
On you all trying to hit 10s on a stock internal motor?
Originally Posted by BMR Fabrication Inc.
Yep, stock internals. If it would just stop raining down here for one night, we could get to the track and run that 10. Our track is open for test and tune every Thursday and Saturday but it has rained the last 2 weeks straight and is supposed to rain every day this week also
