question for the big HP guys...
Old 08-10-2004, 11:50 AM
Tiago's Avatar
Default question for the big HP guys...
2 actually
1. What headgaskets should I go with running a 99 head. Ive read some issues on what gasket to use on different years?
2. What piston rings to run? Gapping info would be nice as well.
I have big goals for this engine
Old 08-10-2004, 11:57 AM
y2khawk's Avatar
How big is big
Old 08-10-2004, 12:06 PM
Tiago's Avatar
LOL, ok, at least 800 rwhp if thats all the heads will go before they lift. I intend on running the same bottom end later on with different heads for more power hopufully.
Old 08-10-2004, 12:16 PM
y2khawk's Avatar
Well
I'm running GM 6.0L gaskets w/ run of the mill ARP head studs. No o-rings, and no lifting we've noticed to far.
For rings, I'm using Total Seal standard gap'd rings. I've got a wierd ring pack size so I'm limited on what's available versus having them made. I'm stuck with their standard classic race series of rings for now.
I'm currently running .0065 * bore on top, .0055 * bore on 2nd ring. It's a litte more blow by at idle than most want, but it seals up well under power and my dry sump takes care of evacuating the crank case at speed.
FWIW, i'm just about 900RWHP based on what it's run and what it weighs. No dyno numbers, it spins the tires past 18 psi
Old 08-10-2004, 12:27 PM
Tiago's Avatar
Any opinions on the Diamond rings they offer? Im deffinately using a set of their pistons.
Harlan are you using 6L heads too? Or do the 6L head gaskets work on a "stock" 5.7L head?
Old 08-10-2004, 12:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,113 Likes on 730 Posts
I am running a Speed Inc. Sportsman shortblock. I am running Diamond -8.6cc FI pistons with whatever rings they use. Car runs pretty clean and we are very impressed with how clean the car runs down the track. I am running 6.0 heads and 6.0 GM MLS headgaskets with the fancier H11 head studs. I have seen 17 psi on the dyno and 15 psi or so at the track.
Old 08-10-2004, 12:48 PM
PurEvl's Avatar
I run a felpro with 6.0l heads
Old 08-10-2004, 12:58 PM
MIGHTYMOUSE's Avatar
i run cometic replacement gaskets, but only because the gm gaskets dont work with my 98 heads (got the notch), also run stock replacement arp studs.
Old 08-10-2004, 12:59 PM
y2khawk's Avatar
Never used the rings from Diamond, so can't comment.
yes, 6.0L heads. Using the 6.0 gaskets due to the chamber diameter of the head. They would work w/ a 5.7L head, would just move the gakest bore out more than normal. Some have commented on that being a good thing anyway.
Old 08-10-2004, 01:12 PM
Tiago's Avatar
I thought the 99s also had the "notch"?
Old 08-10-2004, 02:18 PM
i dont know enough to say if they do or don't.. just look for it
Old 08-10-2004, 03:13 PM
NA$TY-TA's Avatar
I blew a whole out of the notch and took a chunk of the block with it on my 98 heads....... 6.0L now and ARP normal head studs. I hope to make 700 with my new FMIC and pullying up.
Old 08-10-2004, 03:24 PM
Tiago's Avatar
I sure hope I don't blow a hole through the block because of some F'n heads.
Old 08-10-2004, 04:27 PM
my notched heads are fine.
Old 08-10-2004, 07:26 PM
Malicious's Avatar
Sorry to hear bout what happened T, good luck with the new stuff, will try to catch up on it soon as I get back!
Old 08-11-2004, 06:14 AM
smokinHawk's Avatar
the 99's dont have notched heads
why dont you 98'ers get some 99 and up heads. ;0
Old 08-11-2004, 07:48 AM
Tiago's Avatar
So what is recommended? Run cometic gaskets or stock GM MLS?
Old 08-11-2004, 10:20 AM
smokinHawk's Avatar
the gms are cheaper and just as good, so if you dont need a specific thickness get the GMs
