LS2 Block Part Number
Old 08-12-2004, 06:05 PM
NoOne's Avatar
Default LS2 Block Part Number
12589485
Available November timeframe.
Old 08-12-2004, 11:07 PM
y2khawk's Avatar
Holy blast from the past!!
Old 08-14-2004, 02:38 AM
C4VetteLS1's Avatar
Any idea of what cost will be?
Old 08-14-2004, 07:31 AM
NoOne's Avatar
I would expect it to be in line with the current LS1 block, around 700 dollars.
Old 09-01-2004, 09:32 AM
OWENMUSTANG's Avatar
Originally Posted by NoOne
12589485
thanks for the update..
side note. you have one of the sweetest cars i've seen here!
black rx7 w/ ls1. thats cool
Old 09-05-2004, 12:24 PM
ls1/7's Avatar
well i havent read too much on the new ls2 block but will ls1 parts fit on ls2 block? internals and such? just thinking how nice it would be to have a 6.0 alum. block to play with in my rx7
Old 09-05-2004, 12:55 PM
Z06Cam's Avatar
The heads should fit. The LS2 cam is designed a little differently, and obviously the pistons from an LS1 won't fit due to the difference in bore diameter.
Old 09-05-2004, 10:00 PM
ls1/7's Avatar
yeah i figured i would have to get different pistons , the heads fitting sounds good but what about the crank?
doesnt the ls2 heads have 3 valves per cylindar? i cant remember but i thought i heard this. IF true i wounder how the other heads 5.7 would preform? hummmm wonder if it would raise the conpression ratio like the 5.3 heads do for the ls1.
Old 09-05-2004, 10:01 PM
Z06Cam's Avatar
Don't know about the crank yet. The LS2 uses a LS6 style head, 2 valves/cylinder. You won't change the compression with LS6 heads, since they are pretty much the same.
Old 09-10-2004, 09:01 PM
screamn03's Avatar
So can we finally make a sumwhat cheap 408 with an aluminum block?
Quick Reply: LS2 Block Part Number
