Automotive News, Media & Press Television | Magazines | Industry News
New Z06 Info
Old Nov 10, 2004 | 08:37 AM
NIRVANA's Avatar
Default New Z06 Info
6-piston front and 4-piston rear calipers
• Cross-drilled rotors
• Aluminum engine block with 104.8-mm bores and pressed-in liners
• Forged steel crankshaft with 101.6-mm stroke
• 6-bolt, forged steel main bearing caps
• Titanium connecting rods
• Cast aluminum flat-top pistons
• Racing-derived CNC-ported aluminum cylinder heads with 70-cc chambers
• 56mm titanium intake valves
• 41mm sodium-filled exhaust valves
• 11.0:1 compression ratio
• Composite manifold with 90 mm single-bore throttle body
• Camshaft with 15-mm (.591-inch) lift
• Dry-sump oiling system
• 7000-rpm redline
WEIGHT: 3130lbs/1420kg
500hp/475lb-ft torque
Got this from digitalcorvettes.com, seems pretty accurate to me.
If that is a chop, someone did an excellent job.
This info was taken from gminsidenews.com.
Old Nov 10, 2004 | 09:10 AM
riddler's Avatar
Veteran: Air Force
Those statistics make me
Old Nov 10, 2004 | 09:34 AM
Checkmate's Avatar
The stats are good, but I am very disappointed in the lack of change in the front-end. Especially after Dave hill said it would be different.
Old Nov 10, 2004 | 10:16 AM
NIRVANA's Avatar
Bear in mind that those are not official photos and could just be a good photochop. I guess we'll find out for sure once the NAIAS starts in January.
Old Nov 10, 2004 | 10:22 AM
Fulton 1's Avatar
Here's a photoshopped version that a member (M-INENT-1) did over at DC. Its black, lowered, and has some other subtle changes (rear wheel alignment I think). Looks awesome IMO.
Old Nov 10, 2004 | 10:27 AM
sunsetz28's Avatar
Looks like pure evil in black!
Old Nov 10, 2004 | 10:30 AM
mySStery_machine's Avatar
The black version is SICK, I wouldn't want to even be in the same area code with a car looking that mean from the factory. Now if all the specs on top are correct that is one bad momma. But as is said before, only time (January to be exact) will tell.
Old Nov 10, 2004 | 12:13 PM
Red Shift's Avatar
I've never heard of titanium rods.
Old Nov 10, 2004 | 12:16 PM
Shinkaze's Avatar
Gulp!
My M3 just pissed it's pants and hid in the Garage where my Trans Am is currenty mocking it.
-Adam
Old Nov 10, 2004 | 12:20 PM
Red Shift's Avatar
Originally Posted by Shinkaze
Gulp!
-Adam
The M3 looks so good that they don't have to be the faster car.
Old Nov 10, 2004 | 02:43 PM
Ravenous T\A's Avatar
I was hopeing for the 575hp but it looks awesome, wonder if it gonna be in the XLR price range???
Old Nov 10, 2004 | 03:08 PM
DaveSchott's Avatar
Those specs sound as made-up as the pic. dry sump? also, go price Ti rods and valves.
Old Nov 10, 2004 | 03:15 PM
BadAndy's Avatar
Ti valves wouldn't surprise me at all, especially with the 7,000rpm redline. Ti connecting rods would be a different story.
Old Nov 10, 2004 | 03:38 PM
NIRVANA's Avatar
I thought I read somewhere that they didn't want to stray too far away from the last Z06 pricing, so I'm guessing it'll be somewhere in the $55K range.
Old Nov 10, 2004 | 04:49 PM
WILWAXU's Avatar
Photoshop or not. I like it.
Rumor mill on price was in the $70K's. Hoping that's not true..
Old Nov 10, 2004 | 05:30 PM
Shinkaze's Avatar
sure would be nice if it was at lease close
Serriously though, I'm willing to bet the Z06 will increase a bit in price. The reason I say that is the new Z51 option is almost as much of a step up (performance wise) over the base car as the Z06 was (minus the HP increase). That leads me to think that GM wanted the Z51 to bridge the price gap between the base an a higher price Z06....that's my Swag.... no basis in fact of course .
Old Nov 10, 2004 | 05:52 PM
Sport Side's Avatar
I might be imagining things, but when I looked at the Spy Shots of the Z, the front air opening looked much larger than whats shown here.
That is very similiar to the C6 with a tiny hood scoop, when only looking at the front fascia area
Old Nov 10, 2004 | 05:59 PM
Shinkaze's Avatar
Also the nose looks longer in the spy photos.
Old Nov 10, 2004 | 06:07 PM
Sport Side's Avatar
Looking at the spy shots, are the head lights going to be blacked out behind the lenses?
Or is that just some sorta camo for....idk
Old Nov 10, 2004 | 06:31 PM
Shinkaze's Avatar
Analysis by digital Corvettes.
http://img112.exs.cx/img112/3259/dig...s_analysis.jpg
