Part # for the LS2 block?
Originally Posted by Black Sunshine/ 00SS
And components needed to make it work in a F-body? Thanks.
PM or email me if you would like detailed pricing on everthing you will need.
Location: Formerly Hayden, AL . . . Now Attleboro Falls, MA
So can you just run the LS1/6 valley cover and knock sensors, or are you running the car with no knock sensor input to the PCM?
The Bull
No, you can't run the LS1/6 valley cover. The block doesn't have provisions for knock sensors in that location. You can either make a template of a LS1 valley cover and cut it out of aluminum like we did on a couple cars here after deleting the knock sensors. Then you just zero them out in the PCM. That likely will be the case for Harold's situation too.
The LS2 knock sensors are located down lower on the block, on opposite sides along the crankshaft instead of above the camshaft.
The Bull
That is correct. A lot of the big cube, big cam or solid roller cam cars have to zero them out anyway because they get freaked out. Once you get the tuning figured out you really can run without them. It just makes it risky in cases where you are causing any detonation.
The Bull
Like KJ said, it's a different sensor all together. The current one is a small thread into a pedestal. The new ones are completely different. Plus the sensitivity is going to be completely different too. I wouldn't suggest it because the PCM software is not optimized to handle that. It's looking at a known equation based on it's current location not the new one. I'd rather zero them out then try that.
Could it be possible to adjust the signal coming from the ls2 knock sensors so that the ls1 pcm would read it? Like with a set of resistors, etc. wired into the extension that you use on the ls1 harness to connect to the ls2 knock sensor location?
I suppose that one would need to know exactly what the output voltage signals for the ls1 and ls2 sensors were, but after that it "might" not be that hard . . .
I see what you're saying. Since knock sensors are little microphones, the audible frequency of the knock will be different in this location than in the lifter valley.
Personally I'm willing to run without them.
