The Perfect Wideband for HP Tuners
Old 11-18-2004, 09:18 PM
ataylors's Avatar
Default The Perfect Wideband for HP Tuners
This is a REALLY bad pic but you get the idea
Old 11-18-2004, 09:28 PM
LS1Tech Sponsor
hellbents10's Avatar
I see the normal bosch o2 with a connector and some wire. Is that it. I guess this leads me to my next question. How does this interface with HPtuners???
Old 11-18-2004, 09:29 PM
ataylors's Avatar
right to your EIO
Old 11-18-2004, 09:30 PM
ataylors's Avatar
oh and the other good part is I am told it goes for $200
Old 11-18-2004, 09:31 PM
HumpinSS's Avatar
Looks like some type of voltage converter right in the the wire there
Old 11-18-2004, 09:40 PM
Mallett396's Avatar
No, that's just the standard connector for the Bosch o2 sensor.
Old 11-18-2004, 09:42 PM
HumpinSS's Avatar
Well if that is the case why do i have this WB box here i can just run straight of my LH1 to the EIO and call it a day
Old 11-18-2004, 09:46 PM
slow's Avatar
please give some info on that unit, i've heard about such an unit existing.
I need a similar device, and the price is right
Ryan
Old 11-18-2004, 10:01 PM
Super-Guy's Avatar
O.K. guys dumb question, go easy on me. I am new to this kind of thing. What does a wideband do for you ontop of what the HP Tuner already does?
Old 11-18-2004, 10:08 PM
horist's Avatar
Wideband is more accurate for determine how lean/rich you are running
Your car stock has 2 narrowband O2 sensors, these sensors operate between 0 and 1000 mv ... however they are only accurate at or around 14.7:1 Air Fuel Ratio
The further you go away from 14.7:1 (either direction) the less and less accurate they are
Wideband operates from 0 to 5 volts and I think has a useable range of 10-20 Air Fuel Ratio? It is VERY accurate ...
So by logging the AFR using an accurate wideband you can more easily and safely dial the tune in
Old 11-18-2004, 10:09 PM
Black02SS's Avatar
The wideband will alow you to get real time on the road air fuel readings. This allows for more precise programming of the PCM.
Old 11-18-2004, 10:14 PM
2MuchRiceMakesMeSick's Avatar
Will that work? I thougth in order for a wideband to stay accurate it had to have a control box (brain) and be calabrated every once in a while?
Old 11-18-2004, 10:15 PM
slow's Avatar
looks like is has a simply controller built in
crosses fingers
Ryan
Old 11-18-2004, 10:16 PM
ataylors's Avatar
From the info I have:
"The XX is a complete wideband controller built into a sealed cable. ....includes digital input, output, and 2 programmable analog outputs...
Old 11-18-2004, 10:35 PM
Turo's Avatar
where can we get something like this?
Old 11-18-2004, 10:37 PM
ataylors's Avatar
Pre orders will be in a couple of weeks, they should be fully available in about 4 weeks!!! Merry Christmas!!!
Old 11-18-2004, 10:49 PM
horist's Avatar
Is that a Bosch LSU4/LSU4.2 sensor? or is it one of the pricey ones?
Old 11-18-2004, 10:51 PM
ataylors's Avatar
its the LSU4.2
Old 11-18-2004, 10:55 PM
horist's Avatar
oh... this is intriguing
Old 11-18-2004, 10:56 PM
ataylors's Avatar
sure is, isnt it!!!
Quick Reply: The Perfect Wideband for HP Tuners
