Question on shimming and porting ls6 oil pump.
Old 12-29-2004, 11:40 PM
Lostpatrolman's Avatar
Default Question on shimming and porting ls6 oil pump.
I just bought an ls6 oil pump and was wonderign if anyone had a link of how to port and shim it? Thanks.
Old 12-29-2004, 11:56 PM
ArKay99's Avatar
Interested in this also.
Old 01-01-2005, 08:37 PM
rufretic's Avatar
anyone? I would also like to know how.
Old 01-01-2005, 09:24 PM
NLang's Avatar
Just pull the front cover off the pump and pull the two gears. You'll see the casting flash in the main oil track at both the entry and exit ports. Your goal is to smooth the passage/transitions, that's it. For shimming, remove the relief valve cap, pull out the spring, measure its OD, and that's the OD of the shim you'll need. I probably wouldn't shim it more than .125". You can purchase shim stock from one of the many hardware stores around, or from www.McMaster-Carr.com.
Quick Reply: Question on shimming and porting ls6 oil pump.
