Harland Sharp Rocker Failure
Old 01-02-2005, 02:44 AM
mach1's Avatar
Default Harland Sharp Rocker Failure
Pulled my valve covers and got a late xmas gift. I guess 550lbs of open pressure is too much for these little guys, shaft mount time... I figured it would be good to post in internal engine tech because the HS rockers are getting popular on ls1's.
Old 01-02-2005, 03:32 AM
ls1 1990 VN's Avatar
How old are they, what mileage have they done, as mine are being installed this month.
Old 01-02-2005, 04:05 PM
ataylors's Avatar
good thing is that you can send it back and get it replaced and sell the set to get some of your money back.
Old 01-02-2005, 05:01 PM
Beast96Z's Avatar
550lbs of open pressure. You won't see many LS-1 guys with that kinda pressure unless they are solid roller, then shaft mounts are a must.
Old 01-03-2005, 09:06 AM
mach1's Avatar
They are around 3 years old, about 10,000 miles on the setup, only 2,000 with the solid roller setup.
Quick Reply: Harland Sharp Rocker Failure
