What should I get? 382 stroker or 388 all bore?
Old Jan 8, 2005 | 02:01 AM
texada's Avatar
Default What should I get? 382 stroker or 388 all bore?
The car is a street car with ocassional passes at the track. which would be a better performance set up? 382 stroker or 388 all bore? I want a mild street car that run mid to low 11's with a good idle. Help me choose between the two?
Old Jan 8, 2005 | 05:27 AM
Nate_Taufer's Avatar
go 388 all bore. i would love to have that motor. 393 is the next motor in my stable.
Nate
Old Jan 8, 2005 | 12:24 PM
texada's Avatar
I wonder how the torque throughout the power band stack up against each other? Someone ha sto know this?
Old Jan 8, 2005 | 12:32 PM
SSPerformance's Avatar
my 393 is sitting here waiting to be put in.....393 will cost a lil more with the sleved block and all
Old Jan 8, 2005 | 12:55 PM
SAM98WS6's Avatar
383 stroker. Torque is nice
Old Jan 8, 2005 | 01:01 PM
texada's Avatar
I wonder what the torque band throught out the power range compare between the two? Anyone???
Old Jan 8, 2005 | 01:32 PM
destroyerSS's Avatar
Try getting in touch with NOGO cause i think his motor is an all bore and if i'm thinking right he had problems at one time. I would go stroker
Old Jan 8, 2005 | 01:39 PM
Problems with what the sleves? if u have a good shop do the sleeving u wont have a problem
destroyerSS what town do u live in....i live right by goshen
Old Jan 8, 2005 | 01:58 PM
I live in the town of deerpark about 5 mile's from Port Jervis SORRY
Old Jan 8, 2005 | 04:20 PM
v8pwr's Avatar
Default Go All Bore
If you want to compare the graphs look @ MTI's site . I would go all bore there is just no comparison . A stroker makes more torque @ lower rpm's but if there the same displacement the all bore will make just as much torque just at a higher rpm equalling more POWER . A stroker gives the piston more leverage against the crank but an all bore increases valve area and gives more piston area to push down on the crank . The cost of either are pretty close .
Old Jan 8, 2005 | 05:06 PM
SAM98WS6's Avatar
If you go with a forged all bore the cost isnt even close. Stroker is far cheaper.
Old Jan 8, 2005 | 05:13 PM
Wnts2Go10O's Avatar
a stroker will will more power down low, which if its street driven, is what you want. and yea a stroker will be cheaper.
Old Jan 8, 2005 | 05:43 PM
beardWS6's Avatar
You need to talk to a sponsor and let them help you. To each his own. Tell them what you plan on doing with the car and they can fix you up. Good luck. Both motors are sweet!
Old Jan 8, 2005 | 06:04 PM
11 Bravo's Avatar
For your goals, I would look at the stroker. But with an all bore, you are only a crankshaft away from a 427 if you decided to do that in the future.
Old Jan 8, 2005 | 06:59 PM
texada's Avatar
I am not going to spray either. I think if i go with the stock rods and stock crank it will only be a few hundred dollars more to go all bore.
Old Jan 8, 2005 | 07:34 PM
Bo White's Avatar
The only time its cheaper to do the all bore route is to keep the production crank and (if staying n/a) the rods with some ARPs in them otherwise you will spend the same amount on the rotating assembly as you would a stroker and then will have the machine shop bill for the sleeving. If I where to buy a crank/rods/pistons and also sleeve the block it will not be 380ish size engine, more like 420ish. Like 1984camaroZ28 said if you have a good machine shop that know how to put dry sleeves in properly you will not have any trouble out of em.
Old Jan 8, 2005 | 09:42 PM
texada's Avatar
i am going with a wet sleeve block.
Old Jan 8, 2005 | 09:52 PM
if ur staying NA ur wasting ur money.... give bo a pm about a dry sleve block he can hook u up
Old Jan 8, 2005 | 10:04 PM
texada's Avatar
I always thought that wet was better than dry?
Old Jan 8, 2005 | 10:20 PM
some people on the board will tell u that. about 2 months ago i thought the same thing till i called about 90% of the vendors on here that sell sleveed blocks, Cartek , rapid motorsports and all the rest of them. I asked about people having problems with dry sleeves and the all said "The only reason they have problems with the dry sleeves is that the person/shop that installed them did not no what they where doing and if ur gona stay na or even a small shot of n2o u wont have a problem" all of the shop also whould waranty there work.... give BO a pm he will set u up
