Drilling Lifter Cups??
Old 02-02-2005, 10:21 PM
Richiec77's Avatar
Question Drilling Lifter Cups??
Has anyone done this? I search but didn't find any info. I was flipping through "How to Build High-Performance Chevy LS1/LS6 V-8's" by Will Handzel. He shows a picture on pg. 114 of having 2 1/2" holes drilled in each lifter cup on a motor W2W was building. He said it was to help drain out the oil that can and does puddle on top of the lifters. These holes allow the oil to drill back.
Seems simple and straight forward. You drill about a 1/4" above the area where the lifter is supposed to lock in place. Then they are installed facing the outside of the block (towards the pistons). I'm going to replace my lifters as soon as I do a cam swap and was thinking of doing this.
I'll try to find some pics on the net for people (my damn camera broke).
Old 02-03-2005, 03:40 PM
Richiec77's Avatar
What does everyone think? It seems safe considering W2W did that on a 500HP Road Racer.
Old 02-03-2005, 03:58 PM
Cal
Cal's Avatar
Those lifter cups or lifter guides are made of plastic and barely strong enough to keep the lifters from turning as it is. Right now I'm working on a mod to give them more support, because I did have a lifter that turned. So I would not recomend making two holes that big in them; they will be weaker after you do that. It's true that oil pools up in them, but has anyone proven that is a problem?
Old 02-03-2005, 06:20 PM
Richiec77's Avatar
Oh I didn't think about the lifter turning. I guess i'll leave them alone or drill much samller holes.
Old 02-03-2005, 06:46 PM
Cal
Cal's Avatar
Yeah you could drill a pair of 1/8 inch holes in them; I wouldn't go bigger than that. If one of those lifters turns, you have an expensive rebuild coming up. But what did they say was the benefit of draining them, anyway?
Old 02-03-2005, 09:59 PM
427's Avatar
We originally started drilling the return holes to help return the oil on a road race engine. In the early days of Motorola cup we had to use the stock oilpan in a Corvette. We were doing everything possible to keep the pickup covered with oil.
Currently this is our standard practice on gen 3 and 4 engine builds.
Kurt
Old 02-03-2005, 10:06 PM
Cal
Cal's Avatar
OK, good reason. Have you ever seen a lifter turn on any LSx engine?
Old 02-03-2005, 10:12 PM
ls1 joe's Avatar
Kurt do you know anyone that makes a good drag race pan for a LSx type engine, wet sump.
Old 02-03-2005, 10:18 PM
Richiec77's Avatar
Man I'm glad W2W jumped in on this. So Kurt, Will drilling the 1/2" cause a lifter to turn? From the Picture it looks like it is above the area where the lifter (supposidly) locks in place when you turn the cam. I guess I need to take a good look at a set of cups to see where to drill. From Pics I have seen, The spot they drilled is above the webbing in the cup. So I don't think this would have an effect on a lifter turning.
Old 02-03-2005, 10:49 PM
Cal
Cal's Avatar
I think you would be OK drilling there. The place you want to stay away from is near the "bridge" or part where the bolt goes. I think what happens is the plastic flexs up here, allowing a lifter to drop too low in the guide and allow it to turn. Aftermarket cams with their small base circle probably contribute to this also. If you can, post the picture.
Old 02-03-2005, 11:57 PM
Richiec77's Avatar
This is my camera Phone the pic isn't good but will give you an idea. I wish I could increase the resolution. I need a good camera
Old 02-04-2005, 02:33 AM
Cal
Cal's Avatar
Interesting . . . picture is good enough to tell what's going on. I wonder how much oil they hold. I've got the lifter guides out of my engine right now; maybe I'll fill one up with water four times and dump it into a measuring cup and see.
Old 02-04-2005, 07:58 AM
427's Avatar
We have never had a lifter turn in the holder.
Kurt
Old 02-04-2005, 08:01 AM
427's Avatar
Joe,
Canton had a interesting looking street/drag pan at PRI. We have never used one though. Normally on the high hp cars we switch the engine to dry sump.
Kurt
Old 02-04-2005, 08:14 AM
Richiec77's Avatar
Thanks Kurt. I'm really glad you chimed in. Out of curiosity is that 1200HP C5R build up Ron Dukes Motor?
Old 02-04-2005, 08:16 AM
427's Avatar
That engine was sold to Ronnie and originally installed in his black convertible.
Kurt
Old 02-04-2005, 11:51 AM
Richiec77's Avatar
Damn. That is pretty cool. I'm really glad I bought this book. Glad to see why you guy are a leader in this field.
Old 02-04-2005, 12:19 PM
RX-Ben's Avatar
Anything else interesting in the book?
Ben
Old 02-05-2005, 12:24 AM
Richiec77's Avatar
Yes......How about how to remove the engine from the bottom with pics and good Description. Just 1 of the chapters
Quick Reply: Drilling Lifter Cups??
