LS2 Part Numbers Needed
Old Feb 18, 2005 | 09:11 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default LS2 Part Numbers Needed
Does anyone have the part numbers for the following LS2 parts:
Intake manifold
Fuel Rail
Injectors
Throttle Body
Keith
Old Feb 18, 2005 | 11:57 AM
See5's Avatar
Rail - Rail - Fuel...................................P/N 12572174.............---- Qty 1
Asm - Fuel Injector..............................P/N 12569113.....................Qty 8
Clip - Retainer......................................P/N 24503227.....................Qty 8
Bolt - Fuel Rail Attachment...................P/N 12590276.....................Qty 4
Throttle Body w/actuator.......................P/N 12570790....................Qty 1
Fastener - Throttle Body Attach.............P/N 11519971....................Qty 4
Intake Manifold......................................P/N 12589181....................Qty 1
Gasket - Intake to Cyl Head...................P/N 12580833....................Qty 8
Seal - Throttle Body Attach....................P/N 12576549.....................Qty 1
Sensor - MAP.......................................P/N 16212460.....................Qty 1
Bolt - Intake Manifold Attach..................P/N 12552344....................Qty 10
Old Mar 4, 2005 | 11:11 PM
KJ's Avatar
KJ
Got it all in stock!! Let me know if I can help!!
Old Mar 8, 2005 | 09:08 AM
ls1290's Avatar
Do you guys have an adapter that will allow a LS1/LS6 style TB to mount to a LS2 intake?
Keith
Old Mar 8, 2005 | 06:40 PM
ls1290's Avatar
Does anyone know if there is a version of the LS2 throttle body that has the throttle blade actuator on the drivers drive rather than the passenger side?
Keith
Old Mar 8, 2005 | 06:41 PM
See5's Avatar
Really doubt it.
Old Mar 9, 2005 | 10:30 AM
ls1290's Avatar
Really doubt it.
How did you mount the LS2 TB on the FAST intake? I assume some type of adpater plate? If so, could it be used to mount a LS1/LS6 TB to a LS2 intake?
Keith
Old Mar 9, 2005 | 10:43 AM
See5's Avatar
The LS2 TB has the same bolt pattern as the FAST 90 intake and FAST 90 TB so no adapter needed, just wiring for TPS and drive motor.
Old Mar 9, 2005 | 10:54 AM
ls1290's Avatar
So the FAST 90mm TB uses the same bolt pattern as the LS2 Intake/TB?
Keith
Old Mar 9, 2005 | 11:21 AM
See5's Avatar
Affirmative
Old Mar 14, 2005 | 03:18 AM
2001FireBird's Avatar
Hey KJ, do you still have a map sensor? Is it 3 bar?
