Thunder Racing modified spring seats & McGard lugnuts for sale.
9 Second Club NA
Thunder Racing modified spring seats. Machined to fit over Hal shocks so that you can run your stock or stock style springs. $40
McGuard Lugnuts. A set of 10, 12mm x 1.50 RH, chrome plated steel, shank with washer, closed end. $20
9 Second Club NA
9 Second Club NA
RealQuick, sent you a private message.
11SECSS, I have Bogarts as well, Bolted RTs. I used these lugnuts all the way around, but when I upgraded to the 12 bolt with longer standard threads, I had to change lugnuts. These will work with your Bogarts.
I need some about 1.125 long to work on my bogarts will have to look and see if they can be used .
