View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
I was looking into this for my ex's brother (and I confess, I'm a regular lurker over at BITOG)...do a search on here using chucky2 as the posting name...that should get you plenty of material...
Chuck
Chuck
i also a rockland built t56 and the tech who built mine told me to get there brand of syncromesh...i believe him...they ahve some bad *** tranies
my trany shifts feckin awsome
Honda ATF. I've been using for years in my 94 M6 and now I also use it in my 01 M6. I found out about it on Camaroz28.com, it is what everyone recommends over there.
how do i change my tranny fluid? and how much do i need? install university doesn't have anything on this.
my car has 52k miles, 2000 t/a. i think it's a good time to change it out? i bought it used with 41k miles.
theres a drain plug on the lower part of the passenger side, use a 3/8th drive to take it off and drain the fluid. Then screw it back in and the filler plug is on the upper driver side, the tranny will take 4 quarts(prollly little less since you wont get all the old fluid out) you will need to pick up like a pump that will allow you to get the fluid into the tranny(like 3 dollars at autozone). It just screws on the top of the tranny fluid bottle and you pump it by hand to pull it threw a hose into the tranny. Fill her up till fluid starts coming out again, then put the plug back in and call it a day.
Justin
Justin
Justin
Justin
http://www.midwayautosupply.com/deta...ption.asp?8732
So far so good.
