Proof for doubters of the benefits of a ported TB.
Old 03-28-2005, 12:05 AM
Ron78Z&01SS's Avatar
Default Proof for doubters of the benefits of a ported TB.
Hopefully this won't get sent to the sponsor feedback or dyno forums. Lately there's been a lot of talk about the benefits of ported throttle bodies but very littl "real" proof of gains, so I think this would be the place to post for the most people to benefit.
Some people claim the car is more responsive.....honestly I couldn't tell, but my butt-o-meter is hard to impress.
I finally got my car to the dyno this weekend. The first run was with my stock TB & engine coolant @ approx 180*.
Second run was with a ported Bo White TB in place, but I was already warmed up and couldn't get the temp below 200* (it mostly fluxed between 204-201*).
Non Ported: 315 hp & 333 lbtq
Ported : 321 hp & 335 lbtq
The numbers above are gains at peak. Not much of a difference between the two until 3,900 rpm's when the ported one starts to take a 2 hp & tq lead. The torque pretty much fluxes between 2-6 lbs the entire time up to 6,000rpm's. Similar story with the hp, pretty much the same until 3,900 when it gains 2 and increases a little at a time until 5,000rpm's where has (and keeps) an advantage of 6hp up to 6,000rpm's.
I'm sure my numbers would have been closer (if not more) to Bo's gain of 8hp, if my engine temps would have been 20* cooler. I guess I shouldn't have procrastinated on installing my thermostat huh?
Considering how much time you spend at the track over 5,000 rpm's, $65 for a gain of 6hp (at least) is a hell of a good deal.
Old 03-28-2005, 12:11 AM
JRracing's Avatar
Default tb
what do u mean 6hp for 65.00. i've heard of these where do u get them. was it worth it?
Old 03-28-2005, 01:57 AM
Build #1's Avatar
LOL, There are actually people that are against having a bigger throttle body. LOL!!!!
Old 03-28-2005, 08:42 AM
Bo White's Avatar
Glad ya got it on the dyno and got 10 bucks per HP. I do not know where you can buy HP for that much so I think its pretty good. All of the testing I have done or seen done was very controlled and as accurate as possible like the temp and such. Hopefully jrp will get his stuff runnin right and get the testing he his going to do as well. Thanx again
Old 03-28-2005, 04:39 PM
Ron@Vengeance's Avatar
Good to see some back to back dyno pulls. Ported TBs definately benefit most if not all LS1 combinations out there.
Good work Bo!!
Old 03-28-2005, 04:46 PM
BigE's Avatar
https://ls1tech.com/forums/showpost....8&postcount=17
Old 03-28-2005, 04:53 PM
Bo White's Avatar
Good work Bo!!
Thanx man
Old 03-28-2005, 05:31 PM
BLCKBRD's Avatar
when you port your TB, is it just a bolt-in mod or do you need a tune after?
Old 03-28-2005, 05:55 PM
soundengineer's Avatar
its pretty much just a bolt in mod..... your PCM can handle the small amount of change it really has to...
but $65???
dam.... I can do it myself at home for about $12...and about 6 total hours worth of work...take it off the night before...lay in the epoxy...and the copper pipe...
let it dry...go to grinding with the dremel..... clean it up with a little denatured alchohol..... slap it back on the car and drive off
Old 03-28-2005, 07:39 PM
Bo White's Avatar
No programming is required as said before. Most people do not have the equipment or the knowledge to do porting at thier disposal so that is why I am busy doin TBs every week
Old 03-28-2005, 07:47 PM
Bad Seller Alert
getlifted's Avatar
Switched to a 80mm bbk and picked up 2 tenths at the track. No doubts here
Old 03-28-2005, 08:33 PM
DOUBT IT's Avatar
Hey Bo, can you ask Scott if a car that has already been tuned needs another tune after installing your TB?
I'm still gonna get mine done with you, but it'll be a 'lil while now, I'm having to get my hail damage fixed. I probably can't get up with you about it for another few weeks.
Old 03-29-2005, 12:30 AM
psykoTA's Avatar
You may be gettin a call from me when I need one ported
Old 03-29-2005, 06:41 PM
good point....
guess I'm lucky to have the tools and the knowhow
good to see that somebody is able to make a buck off of it...
I have seen your work...and it definately looks GOOD
Old 03-29-2005, 09:12 PM
Bo White's Avatar
Thanx, Im not makin a killin off of it thats for sure lol.
Old 03-30-2005, 08:37 AM
pewterta's Avatar
dude and seriouisly who the hell is goingn to spend 6 hours of there time..portiing when they can jus pay 65 and be done with iit
Originally Posted by soundengineer
good point....
Old 03-30-2005, 11:31 AM
newpew02's Avatar
I agree, I can spend 6 hours doing more productive things. $65-$75 is a great deal in my opinion. (I spent $75)
Old 03-30-2005, 02:37 PM
LS1BlackBird99's Avatar
I want to get one soon. Do you have a way of getting cores for those of us with DD cars?
Old 03-30-2005, 03:20 PM
Bo White's Avatar
I have a limited amount of cores and they come and go and have a waiting list on them. I do not take payment unless I have a TB that I can do then for them.
Old 03-31-2005, 09:12 AM
-Q-
-Q-'s Avatar
There's another core on the way to you. Thanks again, Bo!!
