Sponsored by: DashLynx
T/A Blue Gauges - WRITE UP
Old 04-28-2005, 12:53 PM
InfiniteReality's Avatar
Default T/A Blue Gauges - WRITE UP
If your have a Trans Am, how would you like blue gauges? I’ve always wanted something different than red ones, but never really took the time to see how to do it till the other day. After doing a lot of research on Camaro gauges versus Trans Ams, I found that they’re very similar in fit. And so, my project begins….
In this write-up, I am not responsible for any damage you do to your car.
MATERIALS
Camaro Reverse Indiglo Gauges (Pick what style, I have the 2nd one)
http://www.procarparts.com/store-lis...0&cat=3&sub=37
FOUR #74 Blue LED Replacement Bulbs
http://autolumination.com/74.htm
98-up Camaro HVAC & Headlight Switch
E-Bay is your best bet for this or an F-Body Salvage Yard
ONE 5mm Blue LED & 390 Ohm Resistor
Radio Shack is you easiest bet
SPEEDO & TACH GAUGE CLUSTER
Remove the outside bezel of sorts and make sure to unplug your fog light switch. Be careful around the clear lense of the cluster as you can EASILY scratch it. Then, just four 9/32” bolts around the perimeter of the cluster and it pulls out. Also, again, be careful of the clear lense. Once this is out, you can see how to pop the clear lense off. Now it’s time to start cutting up your brand new Reverse Indiglo Camaro Gauges! CAREFULLY cut the sides around where the indicator lights go as well as the very bottom corners. This will be trial and error till you can fit them. I kept putting mine up to my bezel to get them to fit properly before actually installing them. When you have it nice and pretty, slide them on top of your gauges. Get all the needles through the holes and slide it in place. After this, I used some double-sided tape to keep the gauges in place because the connector for them is at the bottom and when I went to install mine they slide around. Now put your lense back on and be careful that all the needles are out of the way before popping it on.
Time to wire up the transformer for your gauges. I wired mine up to my fog light switch for the reason being that the wire was bigger than the parking light switch. I used a Quick Splice connector to tap into the wires. I’m sorry, but I don’t know the color of the wires off hand. Use a multi-meter to test them and tap the proper ones. I mounted the switch under the dash, which will be the next section. Before you install the cluster bezel back, go down to HEADLIGHT SWITCH and do that step, then afterwards you can reverse the above procedure to put the gauges back in the car. Make sure to test them to make sure they work before putting it all back together.
MOUNT DIMMER SWITCH & DISCONNECT STEERING WHEEL BUTTONS
To remove the knee panel, remove the two 9/32” bolts at the bottom, 2 Phillips head screws and remove. Remember to unplug the hatch button as well. If you look by the steering column you will see a set of 4 wires coming out covered in a gray sheath. Follow it and it will follow to a plug. If you cut the gray wire on it and tape it up, that will be the one for the illumination. Since I can’t use my steering wheel controls due to my screen, I just unplugged the entire plug. While under there you can find a place to mount the dimmer/color switch for your gauges. Sorry I have no pictures of where I mounted mine. Before putting the panel back on wait till it’s dark so you can adjust the brightness and color of your gauges to you liking.
HVAC SWITCH
Carefully pop off the bezel around the radio. Remove the two 9/32” bolts on the sides of the HVAC and slide it out. Remove the ***** around the gauge by sliding them off. Then you’ll see a set of tabs on the top and there is also some on bottom. Pop that off and the face will slide right off. Careful of the defroster button and spring. Now you can put the Camaro face on and replace the ***** with the T/A ones or Camaro, you’re choice. If you look on the back of the HVAC, you’ll see 2 little sockets. Unplug those, pull out the stock bulbs and replace with 2 blue #74 LED bulbs. Test them to make sure they work. If they don’t, pull them out and flip 180 degrees in put them back in. Reverse everything to put it back together.
HEADLIGHT SWITCH
Carefully pop out the switch and unplug it all. Remove the dimmer switch from the side, it will just pop off. Now remove the clear plastic around the switch. Twist the actual switch itself and you will be able to remove it. You will see a small circle with a slit in it for the illumination. Using a small flathead screwdriver, remove the bulb. Using a grinding wheel, I ground down my LED to fit inside the hole on the switch itself. Be careful not to go too far and grind on the metal piece inside the LED as that’s for the light.
Now you can solder the resistor to the positive side of the LED leg. It will be the longer leg of the 2 on the LED. Now place the LED in the hole on the switch and solder the contacts. The positive contact should be the ones closest to the edge of the switch. Now you can put the switch back together. Peel off the face of your stock switch and off the Camaro switch very carefully and slowly. Put the Camaro face on your Trans Am switch. Now you can plug ALL plugs back into the switch and test. Then push it back in the dash.
DOOR LIGHTS
Remove the Phillips head screw and pop off the door lock cover. Carefully slide off the door handle bezel and remove the bulb in the back. You will need to drill out the red lense inside where the bulb goes. ONLY drill out the bottom of it and leave the top intact so you will have something to lock your socket back in place. This will be trial and error. I’d drill a little bit, check to see if all the red lense was gone with a flash light and keep going until it was. When you have all the red gone you can bring it back to the car. On the socket, remove the #74 bulb and replace it with the #74 blue LED bulb. Verify it works and re-install it back to the door. Repeat on the other door.
You should be done, wait till night time (or in a garage) to adjust your brightness of the gauges and admire your work!!!
Old 04-28-2005, 01:20 PM
Slammed-am's Avatar
Excellent write up and work. Thank you.
Would there be any way to do this, but in led-red?
Old 04-28-2005, 01:25 PM
thanks!
I don't see why not. Just leave your stock faces on and swap out the bulbs. Swap out the bulbs behind the gauges too.
Old 04-28-2005, 03:41 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
damnthat looks fantastic. I am thinking about overhauling my interior in blue or green/blue interior LED's. Thanks for the excellent write up.
Brad
Old 04-28-2005, 05:05 PM
Jake19_2's Avatar
Brad
I notice those guage overlays are only for 97-2000, anyone know if they would work on 2001 and up t/a.
Old 04-28-2005, 05:38 PM
check out the indicator lights, if anything that's what would have changed... I
Old 04-28-2005, 06:20 PM
Onyx Z's Avatar
A 98's high beam indicator is swapped with the service vehicle light and vice-versa.
Old 04-28-2005, 06:23 PM
Slammed-am's Avatar
Originally Posted by InfiniteReality
thanks!
Cool.
Do you know of any good places to pick up the bulbs, and do you know part numbers?
Old 04-28-2005, 06:28 PM
LS1_SS's Avatar
I can get you hyperwhites for the vluster, hvac, and the headlight switch!! PM me!
-Nathan
Old 04-28-2005, 06:38 PM
That's the man you need to talk too!
Old 04-29-2005, 11:24 AM
I forgot to mention that on the LEDs for the headlight and HVAC switch, I grounded them flat on the tops to dispurse the light better.
Old 02-02-2006, 11:13 PM
1998TA__1991RS's Avatar
if you are looking down on the headlight switch from the top and the **** is facing forward, which one is the posative side?
Old 02-03-2006, 07:50 AM
I'm not sure, I don't remember. Just use a test light or multimeter to check. Also you can run leads off your LED and just into the dash light wire on the harness. It's way easier than soldering it to those contacts.
Old 02-03-2006, 09:59 AM
so i could run it to a posative lead then just ground it somewhere else?
Old 02-03-2006, 10:05 AM
95formulalt1's Avatar
i did this in my old camaro........blue it looked good at night but then i started seeing dark spots!!! but it did look good when it was first done!!
Old 02-03-2006, 04:53 PM
Yep you should have no problems doing that, just as long as the positive is for the dash lights. Grounding can be anywhere.
I've had mine installed for 9 months now and I have zero hot spots and I don't expect any to appear.
Old 02-03-2006, 05:07 PM
ok i got a blue 5mm led (5 volt,30mA,300mcd), the only resistor i could find that was close was 330ohm. is this going to work? do i need a brighter led?
Old 02-03-2006, 11:27 PM
????? anyone
Old 02-03-2006, 11:48 PM
HotWhipT/A's Avatar
300mcd is like nothing behind the controls.....ask me how I know. Did you get those at Radio Shack too? I had to buy some blue leds from ledgauges.com. I think the guy to look up on here is like LS1_SS or something. Anyways these leds from him are 12,000 mcd. I thought that they might be too bright and show hot spots but they don't. It was $2 a led + coulpe dollars shipping
Old 02-03-2006, 11:50 PM
ill take it back then and just get some brighter ones, what size resistor should i use?
Quick Reply: T/A Blue Gauges - WRITE UP
