Just starting head porting project
Old 05-03-2005, 03:00 PM
99blancoSS's Avatar
Default Just starting head porting project
Some early pics, Got bored while waiting for the porting kit to arrive so I started a little with the dremel...
Attached Thumbnails Just starting head porting project-1getting-started.jpg   Just starting head porting project-tool.jpg
Old 05-03-2005, 03:11 PM
Bo White's Avatar
Wait on the kit and then start slingin aluminum chips
Old 05-04-2005, 02:50 PM
99blancoSS's Avatar
Do you take that bump out of the exaust by the header side in front of the valve guide a few cm's? Also how big do you make the intake runners? how wide?
Old 05-04-2005, 02:55 PM
Bo White's Avatar
Be careful on the small bump in the roof of the exhaust port. That is there for water jacket clearance so only blend it into the roof:
Old 05-04-2005, 03:00 PM
Cal
Cal's Avatar
That cut-away view is very useful . . . makes it easy to visualize what needs to be done. You're a nice guy for sharing, Bo!
Old 05-04-2005, 03:11 PM
99blancoSS's Avatar
Sweet, thx Bo
Old 05-04-2005, 06:27 PM
Bill Bowling's Avatar
Talking
Where did you get your porting kit? I was thinking I might do a port job. I use to do them on motorcycles but not a LS1. Do you have a write up on where to remove and how much?
Thanks.
Bill
Old 05-04-2005, 07:37 PM
gollum's Avatar
Default 4.00" STROKER (383) with STOCK HEADS.
I think our stock LS1 heads flow enough air as is. Ultimatly all we need is a 4.00" crankshaft. My 347 makes good power and will rev very easily to 7000 with just a cam (224/228 112lsa, 108cl) and headers. What our cars need more of is "midrange torque" for acceleration. So while my engine is apart I will just clean up and smooth area under the valves and perform a good quality valve job. I will put off buying higher flowing heads for now and take advantage of the midrange torque the 4.00" kit will give me.
