Predator for sale
Old May 25, 2005 | 10:30 AM
02 Pewter LS1's Avatar
Default Predator for sale
I have no use for this since I own Flashscan. This unit will need to go back to Diablo for a reflash to use in another car. They charge $75.00 to do this. Comes with box instructions and is in mint condition.
Yours for $200.00 shipped.
Old May 25, 2005 | 10:39 AM
Black2000's Avatar
I am definately interested, but i read that the gear ratio correction doesn't work for diablosport predators, is this true? I didn't see gears in your sig, do you have them? Can anyone verify this?
Old May 25, 2005 | 10:49 AM
It does do the gear correction for our cars. You go in and change the factory tire size then change the actual tire size.
You put in certain size tires between the two tires mentioned above then that will give you your gear ratio. It was a bug in the revision of software that is in all GM predators. They were suppose to do a update to fix the bug but yet has it come out. But the way they tell you to change tire size makes the gear change work just fine. I have 342 gears also.
Old May 25, 2005 | 10:54 AM
RyRy's Avatar
did you see some noticable gains using it?
Old May 25, 2005 | 11:14 AM
It will make more power than stock but it will give you control of your pcm to make changes. For a automatic it's great because it gets rid of TM in the tranny. Most people see a average of 10rwhp sometimes more.
Old May 25, 2005 | 12:46 PM
Sold to ripinz28.
