LS1 pace setter header in a 67 PICS
Old 05-31-2005, 08:23 PM
SatisTraction's Avatar
Default LS1 pace setter header in a 67 PICS
well i finally found some tine to work on the LS1 swap. I need to do some grinding and have them coated. the second tube back may need some work before i coat them. these are the 99 race (no smog)1 3/4" headers
Old 06-01-2005, 10:01 PM
ahowudoin's Avatar
How about a ding to get a little clearance? Did you have to modify anything besides the first tube? Looks great! How is the ground clearance?
Old 06-02-2005, 07:36 AM
no problem with the ground. a ding would work but since i am cutting ans welding i may as well do both tubes. i also hade to cut the collectors off and angle them in some. no big deal.
Old 07-05-2005, 06:59 PM
well i finished the drivers side. the ground clearance is as good as it can get. they are about 3/4" from the floors.
now it is about time to send the frame to the blaster for rust removal. I know it looks like crap but I have all new parts to put back on. DSE -2" springs, QA1 shocks, power coated lowers with delrum bushings, speed tech tubular uppers, IROC Z steering box, ETC. all i need is a hotckins sway bar and i will be set!!
Old 07-05-2005, 07:03 PM
here is all my pics
http://www.myonlineimages.com/public.aspx?MemberID=9599
Old 07-06-2005, 05:22 PM
ilovefirstgens's Avatar
A little while back you said how you were going to cut ouit the area of the donor car with the slave and master cylinder and weld that into the 67, hows that coming because i am thinking about doing the same thing, and have fun with rust removal... and keep your fingers there arent cracks in the subframe.
Old 07-06-2005, 06:21 PM
i have not really looked into the master cylinder part yet, sorry i cant help more.
the rust removal is a pain. today i replaced about 2' of the drip rail above the drivers door. it was a major PITA. i can believe the previous owner let it set outside and ruin. if you look at the last pic you can see where it was when i found it. The good news is that I only paid $3400 for seven 1st gen's from that guy. His house looks like a junk yard
Old 07-06-2005, 08:57 PM
What happened to the other 6 because im looking for another shell
Old 07-06-2005, 08:59 PM
What happened to the other 6 because im looking for another first gen... just something with a nice outer shell
Old 07-06-2005, 09:28 PM
sold them or used them for parts. there is nothing much left.
Old 07-09-2005, 04:49 PM
69blackwidow's Avatar
did you have any problems with the oil pan or did you buy a custom pan mike
working on 69 camaro ls1 deal
Old 07-09-2005, 09:38 PM
you have to notch the pan for the sterring drag link but that is normal for using the S&P mounts.
Old 10-04-2005, 01:02 AM
82lt1's Avatar
http://store.summitracing.com/defaul...h.asp&N=400091
Are these the ones you ordered?
Old 10-04-2005, 05:35 AM
your link poped up a bunch of stuff. they are for a 99 camaro LS1 with no EGR or smog. i think they called them the race version.
Old 10-07-2005, 12:18 AM
67RSCamaroVette's Avatar
Hey, SatisTraction.
Looks like we're doing the exact same project. Seeing as you've already done your headers, maybe you could help me out. I've got a few questions. Mine should arrive either tomorrow or monday from summit.
1. Why did you angle the collectors? were they pointed down, to where you could gain clearance? Or was it laterally (pigeon toed or duck footed)?
2. Should i, before putting them in with the steering box in place, cut the tubes where it's necessary, (measure down from flange, also cut at flange, )and do the necessary fab work from there, or what? I'm curious as to how you figured all this out. Any help would be greatly appreciated.
My baby's going to the body shop in the next week, as i finished welding in my last piece of sheet metal (left side quarter flare).. so she'll be gone for a while. Also waiting to use the mill at work to finish the oil pan notching process.
Thanks in advance.
olly
Old 10-09-2005, 10:27 PM
ttt. bump
Old 10-10-2005, 12:45 PM
ok, i cut the collector off because i wanted to be able to remove the 1st tube. you just grind the weld off and remove the collector. then cut the 1st tube about 1/2" from the flange. bolt the header on and the steering box. modify as needed. I only needed about a 6" section of straight 3/4" pipe to fill the gap. you can see it in the top pic.
the second tube was almost OK. i just cut it about 1/2" from the flange and then ground off about 1/16" and welded it back up.
Old 10-14-2005, 09:17 PM
I want to go from these to an "X" pipe.. How do i connect any tubing to the collectors? It's gotta be removable. Do i weld on some 3" triangle collector things? I've never seen LS1 headers before. Any help?
Old 10-15-2005, 09:18 AM
i have nto got that far. my car is a total restoration. but yes you would have to weld a flange on.
Old 10-17-2005, 09:40 PM
Heard in the external engine section, that i just get a 3 inch pipe, and clamp it in. I think i'll just do a '45 degree elbow, cut to length to keep the exhaust paralell to the frame, then merge that into a summit 3 inch "X". I'll post on how it turns out.
olly
Quick Reply: LS1 pace setter header in a 67 PICS
