1995 Firebird Formula $2,500, modded
I am selling my 1995 Firebird formula. I just bought a 2001 Corvette Z06 so i plan on devoting all my time and money to that.
Things wrong with it: could use some paint/ body work to be perfect - Seems to run a little rich (could be tune)- transmission slips when shifting above 4,000 rpm - is not tuned for the 3.73 gears (just put them in).
Good stuff:
76,xxx miles
Holley 255LPH fuel pump
Modified SLP Ram Air box
Modified SLP hood
Unorthodox Underdrive pulley
Jet Hot Ceramic Coated Long Tube headers (1 3/4" primaries, 3" collector)
2 1/2" true duals -> X pipe -> GMMG (Sweet Thunder) mufflers -> side exits
8mm Taylor over the valve cover wire kit
NGK TR55 plugs gapped @ .050"
Throttle body coolant bipass
Throttle body air foil
Hypertech 160 degree thermostat
Descreened and ported MAF
Computer tune from Bryan Herter (PCMforless.com)
Gunmetal Corvette Zr1 rims (17x9.5 front 17x11 rear)
315 Nitto 555r Drag radials (rear) 275 Continetal Extreme (front)
Removed front crash bar and bumper support
Removed all rear interior pannels in the back
Removed all radiator duct work
Cut open front bumper to be functional
3270lbs - full tank, no passengers
This car will be available Friday, June 10th if it does not sell at the auto auction on Thursday. $2500 non negotiable.
Pictures are here
http://home.earthlink.net/~firebirdformula/
Email me @ ShawnMacAnanny@earthlink.net or IM me on AIM or Yahoo @ ShawnMacAnanny.
Good stuff:
76,xxx miles
Modified SLP hood
Pictures are here
Good stuff:
76,xxx miles
Modified SLP hood
Pictures are here
Good stuff:
76,xxx miles
Modified SLP hood
Pictures are here
Doesnt leak any fluids or burn any oil. Tranny fluid and filter was replaced 6k miles ago. Oil was changed ever 3k will castrol syntec 5w 30, needs to be changed again around 78k. coolant was flushed 6k ago, filled 50/50 with the orange stuff (Dexcool i think) when the thermostat went it. Rear end has 78k on it, gears have 17k (i swapped out the entire rear). That has 75w 90 Mobile 1 in it with GM Posi addative in it. Fluid has about 100 miles on it.
This car is offcially for sale. First $2,500 takes it. By first i mean first person to get me the cash. If i get several offers simultaneosly then who ever offers the most gets it
Sort of like an auction. When buying this car you have 1 week to pick it up and i will need a downpayment if you can't come get it this weekend. If you pay me in full i'll hold the car as long as you like.
Sort of like an auction. When buying this car you have 1 week to pick it up and i will need a downpayment if you can't come get it this weekend. If you pay me in full i'll hold the car as long as you like. email me some pictures of the car, i have cash in hand and desperately need a car! heh. jon.oso@gmail.com and cross streets so i can mapquest the trip back to phoenix AZ
