Stuff 4 Sale
Old Jun 27, 2005 | 04:03 AM
nbm00ws6's Avatar
Default Stuff 4 Sale
Guess I'm going to go a different route with the car. No time to race it anymore due to our girls playing sports and Mollie and I going all different directions with them and none of those directions are to the race track anymore. So my plan is to put the car back close to stock, so I have a lot of stuff for sale.
#1 F-1 Procharger, Steel J-bracket, SDCE 8 Rib spring loaded tensioner,ATI crankshft damper,inlet hat,mounting studs and spacers.=
NEW PRICE=$3800(all is new and never ran more than 10 min)SOLD
#2 FMIC(900 hp),3 inch aluminum piping,t-bolt clamps,silicone hose couplers,silicone transition hose(3 to 3.5 and 3 to 4),ATI Race bypass valve,IAT sensor mounted in 3 inch pipe. This is a complete set up from the supercharger to the throttlebody(everything needed)=$900(all is new and never ran more than 10 min)
#3 Rossler 400 turbo with trans brake,speedo kit installed, midwest 3500 stall torque convertor,gear-venders overdrive unit, steel driveshaft,tranny cooler and lines,factory shifter reworked by Mike Brown to work with the reverse shift pattern in the 400 turbo,crossmember,Spoohn torque arm set up for this tranny,TCI flexplate= $4000(very low miles)added the crossmember/torque arm/flexplate
No Longer For Sale
#4 9 inch moser rear end,3.50 gear(35 spline with a spool) with Spohn drag sway bar= $2200 SOLD
#5 Shortblock=5.3 iron block- bored 125k over to a 3.910 bore-forged pistons-billet rods-stock crank has been keyed for Supercharger-Comp R lifters-cam for supercharger,C5R timing chain,ARP head studs(built by Reckless=Todd Brandon)
Heads= APE stage one ported 6.0 heads,317 casting
Motor is set up at 9.1 compression
For the longblock(no intake,oil pan,or front and rear covers)= $3500 very low miles
Pending Sale
#6 Two 28 X 10.5 X 15 W MT Drags(brand new, never mounted)=$350 Sold
#7 Set of Yellow Terra 1.7 ratio rocker arms(almost new)= $375 Sold
#8 Aeromotive A-1000 fuel pump(used very little)= $175 Sold
#9 Reichard Racing 3.5/6 rib supercharger pulley=$90Sold
#10 Two 15 X 3.5 Weld Drag Lites with Moroso Drag Fronts(8ply),
Two 15 X 10 Weld Drag Lites with 26 X 10.5 X 15 MT Drags(tires have a few passes left)
Lug nuts,spacers, center caps= $600 Sold
#11 Kirkey Economy Drag Seat,aluminum,17.5 hip width,black snap on cover(Brand new, never mounted)= $125Sold
All items are plus shipping
I'll have more stuff for sale, can't remember it all now.
Please email me if you have any questions, pics upon request.
Tom
Old Jun 27, 2005 | 03:27 PM
fattdaddyLS1's Avatar
I PM'ed you at NKFBA site about the 9'
Old Jun 27, 2005 | 04:10 PM
formulajunky's Avatar
Tranny cooler intrested in
Old Jun 27, 2005 | 04:20 PM
blindskater02's Avatar
sent pm on draglites, dibs!!
Old Jun 27, 2005 | 06:51 PM
yea dibs
Old Jun 27, 2005 | 07:10 PM
krl's Avatar
krl
Default pulley
#1 F-1 Procharger, Steel J-bracket, SDCE 8 Rib spring loaded tensioner,ATI crankshft damper,inlet hat,mounting studs and spacers.=$4200(all is new and never ran more than 10 min)
#3 Rossler 400 turbo with trans brake, midwest 3500 stall torque convertor,gear-venders overdrive unit, steel driveshaft,tranny cooler and lines,factory shifter reworked by Mike Brown to work with the reverse shift pattern in the 400 turbo.= $3800(very low miles)
#5 Shortblock=5.3 iron block- bored 125k over to a 3.910 bore-forged pistons-billet rods-stock crank-Comp R lifters-cam for supercharger,C5R timing chain(built by Reckless=Todd Brandon)
Heads= APE ported 6.0 heads,317 casting
Please email me if you have any questions, will have the stuff off the car this week and can take pics then if needed.
Tom
Interested in pulley just need to know if size is right
Old Jul 2, 2005 | 02:30 PM
seadoo's Avatar
call seconds on rims, but i want the fronts only if iwlling to split. if so shipping to 33870 Sebring, Florida. or can split if someone wants rears only thanks.
Old Jul 11, 2005 | 07:43 AM
Lost & Found2's Avatar
What would you be willing to sell the F-1 Procharger and the FMIC for together?
Was there any problems with spacing for the F-1 or the FMIC? Would there be any additional parts needed to mount the F-1 or FMIC?
Pictures would also be great.
Jay
Old Jul 18, 2005 | 11:30 PM
seadoo's Avatar
do we have a update?
Old Jul 19, 2005 | 12:35 AM
Kaneman's Avatar
Will the Yellow Terra rockers fit under the stock valve covers on an 00 Camaro? I am interested if so.
Kane
Old Jul 19, 2005 | 03:54 AM
nbm00ws6's Avatar
Wheels are sold,A-1000 is sold,Rear end is sold along with sway bar,10.5 W's are sold. Working on deal on tranny and supercharger/intercooler but they are still for sale.
Kaneman, yes they fit under stock valve covers, didn't need to grind on heads or valve covers.
Tom
Old Jul 27, 2005 | 07:20 AM
Blown408's Avatar
Has the F-1 and intercooler kit sold yet?
I sent you a couple of PMs.
Old Aug 1, 2005 | 06:50 PM
dans91's Avatar
would you be willing to sell the bypass valve seperate?? I really need one
Old Aug 1, 2005 | 07:10 PM
badazz98transam's Avatar
hey buddy will u take for the back rims.. let me know, email me at brgn3@aol.com
Old Aug 1, 2005 | 08:56 PM
nbm00ws6's Avatar
Bypass valve is included in the fmic deal, and I have a pending sale on it.
Wheels are sold already.
Tom
Old Aug 1, 2005 | 10:45 PM
dans91's Avatar
coolio, well let me know if it falls through. I already have everything else i just need a Bypass valve THANKS
Old Aug 1, 2005 | 10:57 PM
Matt D's Avatar
Retired Street Racer
pics of the kirkey seat to matthewdatri@yahoo.com please!
Old Aug 2, 2005 | 06:58 AM
Blown408's Avatar
Sent paypal for FMIC setup.
Old Aug 19, 2005 | 12:38 AM
LSs1Power's Avatar
Interested in the J steel bracket with the SDEC tension setup only. Send me PM if you want to seperate them.
Old Aug 19, 2005 | 12:53 AM
nbm00ws6's Avatar
These items are sold
