wheel sizing chart
Old 07-04-2005, 08:14 PM
TTSSZ's Avatar
Post wheel sizing chart
new wheel chart.
The left side would be the inner wheel well.
the center line is the mounting surface.
Common sizes from the threads I've read,
and the 3 sets I've had.
zr1's, zo6's, fikses, hre's, stock ect.
If you see mistakes let me know.
scroll down for bigger chart
drive_journey (12-25-2020)
Old 07-04-2005, 10:42 PM
FLAWLS1T/A's Avatar
Amazing
Only If It Was Bigger
This Should Become A Sticky!!@!@!@!%$!!
Old 07-05-2005, 07:46 AM
thesoundandthefury's Avatar
Maybe Xsta Z 28 could proof read it. He's the wheel fitment guru. I love the layout of this chart though. Pretty easy to follow. Kickass job man.
Old 07-05-2005, 08:40 AM
Xsta Z 28's Avatar
Any way for a slightly bigger pic? I haven't finished reviewing it, but it looks like some good info.
Old 07-05-2005, 01:51 PM
FLAWLS1T/A's Avatar
Old 07-05-2005, 09:35 PM
spgino's Avatar
i thought stock rims were 9.5" (for 99 z28)... am I wrong????
Old 07-06-2005, 03:59 PM
Xsta Z 28's Avatar
Stock Z wheels are 8"
Stock SS wheels are 9"
Old 07-06-2005, 05:09 PM
Hawkeye2's Avatar
So, if I'm reading it correctly - eg. rear ZR1 - GS offset - 50mm. Rim width is
11", from mounting surface to the rear is 7 & 11/16ths, that would leave
3 & 5/16ths needed to clear the fender lip. Cest Correct?
Old 07-12-2005, 08:11 AM
Xsta Z 28's Avatar
You are close. You need to take into consideration that the 11" is the dim from the inside of the tire mounting bead. So an advertised 11" wide wheel could have a phyiscal overall width closer to 11 3/4". The typical backspace on a 11" ZR-1 is around 7 15/16" and mathmatically giving you 3 13/16" to clear the quarter lip.
Old 07-12-2005, 10:11 PM
TTSSZ's Avatar
Ya, the rim lip width is a slight plus or minus number on most of them using the info I got from measuring the HRE’s. Some rims have a slightly bigger lip but those are close. I used the same lip width to calculate the backspaces that are shown.
The stock 9” SS rim was 9 ½” out to out - The 11” HRE was 11 7/16” out to out.
Old 08-05-2005, 03:32 PM
Scotty-Z's Avatar
Are you an architect? Those plans and writing look like a drafter's writing.
Old 08-05-2005, 09:08 PM
TTSSZ's Avatar
Yep, Motor head architect with a background in structural engineering.
I was going to dress up the chart a little more but I liked the rough look of it.
More motor head-ish.
Old 08-08-2005, 02:45 PM
1CAMWNDR's Avatar
Hmmm. So a 15"X10.5" with 7.25" backspacing should just fit, right?
The sale on this particular wheel will probably vanish by the time I can afford it, but I am just wondering.
Old 09-22-2005, 06:48 PM
badmfkr's Avatar
Default Ta
Originally Posted by FLAWLS1T/A
Amazing
I dig the look of dark rims / dark paint looks good!
? have you tinted you're windsheild?
Old 10-04-2005, 06:55 PM
justfender6's Avatar
will the c6 rims 18x9.5 w/ +59 offset fit the way all around?
Old 10-04-2005, 10:16 PM
TTSSZ's Avatar
Yes it will fit.
It will have a 7 3/8" backspacing
so it will stick out 1/8" more then the stock rim and be 3/8" in more.
.....as far as I can tell.
Old 10-13-2005, 11:34 AM
10 second playa
Anonymous's Avatar
So a 10" wide wheel no matter what the diameter would fit best with 6.75" of backspacing or a 38mm offset, according to this chart.
On an 02 Z-28 at least.
Correct?
Old 10-13-2005, 04:51 PM
Xsta Z 28's Avatar
38 mm offset would work great on a 10" wide wheel.
Old 10-14-2005, 02:39 PM
10 second playa
Anonymous's Avatar
OK great thanks. If I can order them that way I will.
Old 10-15-2005, 11:00 PM
blue01ta's Avatar
I am wanting to send my factory rear 01/02 WS6 wheels off to be widened to 11" so I can run a 315/35/17 tire. Is it possible to do this without having to do the bfh mod or use a spacer? If so can you tell me what BS and offset I would need. I want the end result to look just like the factory set up but with a wider tire on it and I'm not sure if I have the graph figured out entirely. Any information is greatly appreciated.
Quick Reply: wheel sizing chart
