FS: LS1 Long Block - Houston area
Old Jul 7, 2005 | 06:29 PM
HRJ's Avatar
HRJ
Default FS: LS1 Long Block - Houston area
I have a used 02 LS1 for sale.
Corvette oil pan installed, but the engine came out of a WS6. (We bought a new engine from GM and it had a Vette pan on it so we swapped pans.)
Head casting # is 241
Block casting # is 12559378
Engine was replaced because cylinder #5 was 40psi lower than all other cylinders. Upper compression ring was toast but the cylinder isn't scored at all, but warranty said to put a new engine in the car. (I work at a dealership)
All of the LS1's I've found for sale are in the $1,000-1,300 range, so I'll sell it to one of you guy's for $600.00. Gotta pic it up though.....I'm not shipping it. Too much of a pain in tha ***.
HRJ@LS1GTO.com or cell phone 713-819-5363
EDIT!! I forgot....engine has 37,299 miles
Old Jul 7, 2005 | 07:01 PM
onesweetz06's Avatar
Default shortblock
sent u pm
Old Jul 7, 2005 | 09:05 PM
INVISIBLEZ's Avatar
Voicemail left, and email sent......
Old Jul 7, 2005 | 10:45 PM
redaddiction's Avatar
Damn good deal the block is worth 400-500 alone.
Old Jul 8, 2005 | 10:23 AM
V6 Bird's Avatar
Do you still have this??????
Old Jul 8, 2005 | 10:45 AM
HRJ's Avatar
HRJ
Yes I do
Old Jul 8, 2005 | 11:01 AM
hawgs's Avatar
Any accessories with this? The #5 upper compression ring has been replaced or needs to be?
Old Jul 8, 2005 | 11:12 AM
HRJ's Avatar
HRJ
No accessories.......no repair has been done to the engine. It was simply bolted back together and placed in the crate that the replacement engine came out of.
Old Jul 8, 2005 | 11:28 AM
HRJ's Avatar
HRJ
BTW....to save you from asking...Im firm on this price. The main reason I decided to sell it at this low price is to not have to deal with negotiating. If you want it, $600 takes it.
Old Jul 8, 2005 | 11:38 AM
V6 Bird's Avatar
Who robbed the intake then? Cuz that would be the main reason id pay $600 for it...
Mike
Old Jul 8, 2005 | 11:42 AM
HRJ's Avatar
HRJ
Mike
It went back on the car.......the new engine (part # 89017548) didn't come with an intake.
Old Jul 8, 2005 | 11:47 AM
V6 Bird's Avatar
something dont sound right simply because my last crate motor i got under warranty had intake to oil pan with manifolds etc all in place...Let me give it some thought...I may just go to my local core yard and pick one up for a little less with an intake on it. TTT for ya.
Old Jul 8, 2005 | 12:06 PM
HRJ's Avatar
HRJ
Directly from my ProQuest GM Parts Catalog:
PART# 89017548
GROUP-00.000A
ENGINE,GASOLINE (GOODWRENCH NEW)
USAGE-LS1(F-Y)
YEAR 02-02
QTY 1
IMPORTANT NOTE: CONSISTS OF BLOCK, CRANK W/SEALS & BEARINGS, CAM W/BRGS, CYL HD ASM (W/VALVE TRAIN), OIL PUMP (W/SCRN & HSG W/SEALS & SHF W/SEALS), WATER PMP SHF & CVR (W/SEALS), ROCKER ARM CVRS, TIMING CHAIN (W/SPKTS), PISTON & ROD ASM, OIL FILL CAP, LIFTING BKTS, OIL PAN (Y), CRANKSHAFT BALANCER ASM, OIL LEVEL SENS, SPRK PLUGS. DOES NOT CONTAIN EXHAUST MAN, FLYWHEEL, INTAKE MANIFOLD, FUEL RAIL ASM, THROTTLE BDY.
Old Jul 8, 2005 | 12:53 PM
V6 Bird's Avatar
PART# 89017548
GROUP-00.000A
USAGE-LS1(F-Y)
YEAR 02-02
QTY 1
Thanks for the info....
Im gonna stop by the core yard and see what I can scrounge up there. Thanks anyway.
Old Jul 8, 2005 | 01:18 PM
CMNTMXR57's Avatar
Don't you have a plenum to swap anyway? Even if you don't it gives you more options when you do add it instead fo just an OEM LS6 intake.
I think $600 is a steal for a building block!
Old Jul 8, 2005 | 02:14 PM
HRJ's Avatar
HRJ
No problem
Old Jul 8, 2005 | 02:18 PM
JurisAg02's Avatar
the ls6 intake is not included? Are you positive that it is a simple fix? I only ask because I fear buying it then when taking it to get repaired they come back and tell me the block is cracked or something else that would mean the engine is worthless...anyways, let me know I am interested
thanks!
Old Jul 8, 2005 | 02:34 PM
Mike,
I'd like to know where you can get a longblock ls1 for less thatn 600 bucks around here. Hell find me a 4l80e for that cheap and I'll take it.
600 for this is a good deal the heads are worth 250, the crank 150 and the block 450. Do the math.
Old Jul 8, 2005 | 02:53 PM
HRJ's Avatar
HRJ
Sold!!
Old Jul 8, 2005 | 04:52 PM
Sold!!
