Cheap Throttle Body
Old Jul 7, 2005 | 07:40 PM
Frizzle Fry's Avatar
Default Cheap Throttle Body
Just to get the thing running I'm thinking about using a 4.6-5.3 TB on my LS1. They can be picked up VERY cheap and I've heard they will fit. Anyone else done this or put an LS1 TB on a 4.6-5.3?
I'll dump the $$ on the go-fast stuff later...
Old Jul 7, 2005 | 11:19 PM
red90cobra's Avatar
why just get an ls1 tb from a 00 trans am. I got a stock one I believe. 30shipped. let me know. and yes I believe the tb will fit from a 4.8-5.3.
Old Jul 8, 2005 | 08:42 AM
jimmyblue's Avatar
Truck TB and earlier F-body TBs use a smaller pulley
and different PCV, coolant nipples but the identical
casting to later F-bodies. My ported TB is actually a
truck core with my F-body pulley & IAC motor & PCV
nipple swapped on. The smaller pulley might be more
"friendly" to short-pull gas pedal linkages.
Old Jul 8, 2005 | 09:09 AM
digitalsolo's Avatar
I have one from a truck on my LS1. Exact casting as the one I took off (damaged). The cam looks about the same as the one on the original, but I have a '98, so it has the smaller of the F-Body ones anyway. Fits great, had to bend the PCV tube, but that was the grand total of effort required. The bore, etc. is exactly the same. I was **** and measured with my calipers.
Old Jul 8, 2005 | 09:12 AM
Thanks guys! That's what I was looking for. Great detail Jimmy. PM sent to Red.
Old Jul 8, 2005 | 01:36 PM
LS1GMCTruck's Avatar
Thumbs up That '61 Is The Coolest!
I'm not a huge fan of older Chevy truck body styles...But, I will have to say, that IS by far, one of the most beautiful truck customs that I have ever seen! The bed styling compliments & flows with the rest of the truck better than the factory original. And of course, you chose the best color to show this masterpiece off. Very, very nice job. Gar
Old Jul 8, 2005 | 03:16 PM
I appreciate the complements. That pic is the concept I'm building to. I created it using MS-Paint and PhotoEditor. I'm doing all the body work to match what you see in the concept.
I agree they are not that pretty in stock form (60-66). The current status of the truck can be seen via the link in my sig. It's most likely going to be midnight blue.
Thanks,
Mike
