STD vs SAE dyno differences?
Old 01-13-2002, 03:25 PM
2000TA_Artic_man's Avatar
Default STD vs SAE dyno differences?
I have a question about Std and SAE dyno results. I read that SAE is 60 degree temp, 0% humidity and i think it was 29.18 barometric pressure. So this test can hurt u or make you look better correct?
Lets say its 80 degrees outside and the humidity is around 70, your car would post worst results than it would with SAE corrected numbers... right?
And vice versa...
I did a dyno in 62 degree weather and it was STD, does that mean my SAE corrected could be better? The humidity was higher then 0 too..?
peace...
<img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old 01-14-2002, 10:34 PM
jimbob's Avatar
Default Re: STD vs SAE dyno differences?
This is from a magazine article on "dynojet" dynos.
SAE j1349 correction:
29.23 in/hg.
77 degree temp
0 percent humidity
Standard correction:
29.92 in/hg.
68 degree temp
0 percent humidity
What this all means is that "Standard" will give you 2.6 percent better numbers (very popular for the import crowd). The example the magazine gave was a Vette making 412 (SAE corrected hp). With the Standard correction it made 423. All that you will have to do is multiply your "Standard rwhp" by .974 This should equal SAE (the one everyone uses). Up here in the great white North (Washington) the temps are in the 40-50 degree area, along with 29.9-30 in/hg. So, our numbers are actually corrected down from what it made at the rear. Usually, 96-97 percent of actual posted numbers. If you dyno when it's a hotter temp or higher altitudes the numbers will usually correct up to equal the desired temp, humidity and pressure of the correction factor.
Jim <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" />
Quick Reply: STD vs SAE dyno differences?
