LS7 / C6R Velocity Stack Induction/Injection
Old 07-13-2005, 12:51 PM
LS_RX-7's Avatar
Default LS7 / C6R Velocity Stack Induction/Injection
Hi, I have a couple questions, and am wondering what some of the more experienced opinions are here.
I'm interested in buying an LS7 when they become available, but I would like to either fit the OEM velocity stack injection/induction manifold used on the C6R to the engine, or model one on that and fit that.
I don't think I will be able to buy an LS7 minus the intake manifold/throttle body & and controller/injectors/fuel rails and pressure regulator/beauty covers/camshaft/pushrods/exhaust manifolds, so my first and foremost question is, "Are there any parts centers that I could sell these 100% unused components back to?"
I am not interested in using these components, and don't want them.
My second question is, "Will the C6R velocity stack injection/induction manifold become available anytime soon after the crate LS7?"
All comments and questions are welcome. I would appreciate any info (preferably with sources if possible) that I can get on these topics.
Old 07-13-2005, 03:29 PM
rocketman442's Avatar
I think the injection on the C5R was sourced fron Kinsler. they have a website, not sure what it is. Somebody correct me if I'm wrong.
Old 07-15-2005, 07:16 PM
technical's Avatar
http://www.kinsler.com/
Old 08-27-2005, 07:09 PM
TUF383's Avatar
Default Harrop 8TB manifold
You may want to consider the Harrop Hurricane manifold as we are now tooling up a version for the LS7 & C5R heads.
Old 08-30-2005, 07:18 AM
J-Rod's Avatar
The intake ports on the C5R and Ls7 are similar, but the Kinsler and the Harrop are set up for C5R heads which has a slighly different bolt pattern. from my understanding, you'd need to change the bolt pattern on the Ls7 head to use an 8TB intake, or use C5R heads.
As for the re-sale of parts. You probably need to go the ebay route, or sell them on a site like this one. Most dealerships aren't going to buy takeoffs. Some of the more performance oiented shops like SDPC might. But you'd need to contact them.
Kinsler makes the C5R and C6R stuff. Its a Kinsler base, and Advanced Composite makes the intake tubes. They are a GM/Pratt Miller design, and not for sale as far as I know. So you'd probably need to fabricate your own.
The Harrop unit is a very nice piece.
I'd budget about $5-10K over the price of a Ls7 crate to do an 8TB setup and want to mimic the C5R setup. Less if you don't mind making some allowances
Old 08-30-2005, 05:38 PM
TUF383's Avatar
Smile
...snip ...
Thanks for the compliment.
The new LS7 Hurricane we are currently tooling for will be a direct CNC'd match for the LS7 port, and will be drilled to suite the LS7 (LS1-6) mounting bolts.
We will also off a "small cast port" version that can be CNC ported to suit a modified head port shape.
Old 08-30-2005, 09:04 PM
FASTEST ALL MOTOR LS1 IN THE COUNTRY
CAMN HAWK's Avatar
what kind of gains did you guys see with the hurricane intake?
Old 08-30-2005, 09:42 PM
Restricted User
NOSjohn's Avatar
lurking...
Old 08-31-2005, 09:32 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Would this fit/work with a C5?
Keith
Old 08-31-2005, 02:11 PM
abadss's Avatar
wow, that hurricane manifold is insane! like said before what kind of gains do you see with a 8tb setup? is it worth that much $$$?!!!
Old 09-01-2005, 04:38 AM
BUYAMERICAN's Avatar
Hp & Torque (maybe 30 across the board)...yes...Looks great...yes...EAT MASSIVE AMOUNTS OF FUEL...YES...
Old 09-02-2005, 05:44 AM
TUF383's Avatar
On a 383 with a mild street cam, typical increase over standard LS6 manifold is >40HP.
On a 427 with big heads & cam, we saw >70HP increase over a Fast 90.
Originally Posted by ls1290
Would this fit/work with a C5? Keith
We have 1 guy who has fitted it to a C5. There was some interference with the cowl (which was trimmed) and the left air-pod needed modifying to fit around the power steering reservoir. I will try & find the photos (he is based in Germany!).
It only uses as much as it needs to create the relevant power ... it is not much different (if at all) than the standard manifold for cruising ... the amount of fuel used is almost directly proportional to the gains.
Old 09-02-2005, 12:10 PM
Payton's Avatar
Default height difference
what is the height difference in a Harrop and fast intake/ls6? From the diagram I recieved it appears to be about 1 inch or 2.25 cm. Is this correct?
Old 09-02-2005, 05:55 PM
TUF383's Avatar
It is about 20mm taller to the highest point of the centre cover, and about 40mm taller to the highest point of the trumpet flange/air-pod mount.
Old 09-04-2005, 03:48 PM
Shinsetsu's Avatar
What gains would u get over a stock ls1 intake to this on a stock ls1 engine?
Old 09-04-2005, 04:34 PM
IRONBULL's Avatar
Location: Butler county, right above slimey ass Cincinnati, OH
Goobs of air & fuel............As an american..I like that!!!
Old 09-04-2005, 06:08 PM
TUF383's Avatar
Not much ... the best we have seen on an absolutely stock LS1 is about 35hp.
Old 09-06-2005, 08:12 PM
Shinsetsu's Avatar
pretty good number, since you will have ALOT of room to grow.
and it sounds freaking awesome!!!!!!
Old 09-10-2005, 05:35 PM
CAMN HAWK's Avatar
do these intakes fit in an fbody? and how much do the go for?
Old 09-10-2005, 08:49 PM
TUF383's Avatar
We do not have any version of F-bodies in Aussie ... so we have not been able to confirm a fit.
Not being a forum sponsor, I suspect I am "not allowed" to post the price ... sorry.
Email me at ken@harrop.com.au for drawings/images and pricing.
Quick Reply: LS7 / C6R Velocity Stack Induction/Injection
