Revised fuel injector calc..easy copy and paste
Old 08-04-2005, 03:08 PM
ZL1Killa's Avatar
Default Revised fuel injector calc..easy copy and paste
Here is a modified fuel injector flow rate calculator for those that want an easier way of copying and pasting into your tuning software such as EFI LIVE. I simply made the numbers go vertical instead of horizontal, made it a lot easier to look at and read, again thanks to RedHardSupra for the original table. In this revision you simply change your fuel pressure and your fuel injector rating (lb/hr) and you can see the results in the orange to the right, and then copy and paste those cell contents directly to the table in your tuning program for the injector flow rate. any questions can be sent to sm1218@aol.com
REVISION MADE, PLZ DOWNLOAD NEW REVISION MADE : PLZ ALL DOWNLOAD THAT GOT PREVIOUS VERSION
Quick Reply: Revised fuel injector calc..easy copy and paste
