Crane valve springs
Old Sep 16, 2005 | 03:37 PM
VSGLS1's Avatar
Default Crane valve springs
Crane Cams 1.275" Dual Valve Springs, Good to .650" Lift. Have 3000 miles on them. PN# 40-144832-16. Here is some info found in the Cam sticky from the internal section.
A dual spring setup rated for up to .650 lift. When buying duals you’ll need the dual springs (obviously), titanium retainers, new dual spring seats, and new valve stem seals.
Outer Diameter Outer Spring 1.275
Outer Diameter Inner Spring .937
Inner Diameter Inner Spring .667
Damper No
Seat Pressure @ Installed Height 112 lbs @ 1.800
Open Pressure and Height 352 @ 1.150
Coil Bind 1.045
Maximum Net Lift w/.060" Clearance .650
Average Spring Rate (lbs./in.) 352
Just the springs. $95 shipped. Paypal addy is Sweetss@cfl.rr.com
Old Sep 16, 2005 | 03:41 PM
2KSS's Avatar
PM'd you !!
Also... do you have the retainers and keepers ?
Old Sep 16, 2005 | 03:53 PM
VSGLS1's Avatar
Replied.
Old Sep 18, 2005 | 10:40 AM
VSGLS1's Avatar
Bump, still for sale.
Old Sep 18, 2005 | 12:23 PM
2000 Ultra Z's Avatar
do the heads have to be machined for them to work
Old Sep 18, 2005 | 01:40 PM
VSGLS1's Avatar
Don't think so. You will need new seats to go with the springs though.
Old Sep 21, 2005 | 05:22 PM
VSGLS1's Avatar
Bump, these need a good home.
Old Sep 28, 2005 | 04:16 PM
VSGLS1's Avatar
Bump, still for sale...
Old Sep 30, 2005 | 10:27 AM
VSGLS1's Avatar
Up, for a good home...
Old Oct 1, 2005 | 11:25 AM
darkside98's Avatar
do you have the reatainers?
Old Oct 1, 2005 | 11:34 PM
VSGLS1's Avatar
Just the springs.
Old Oct 11, 2005 | 10:04 AM
VSGLS1's Avatar
$90 shipped...
Old Oct 11, 2005 | 07:36 PM
Stu's '00 Z's Avatar
man....if only these had everything else with them....id be all over it....
o well
bump for ya
Old Oct 11, 2005 | 09:05 PM
Hocky's Avatar
You've got a PM.
Old Oct 11, 2005 | 10:29 PM
VSGLS1's Avatar
Sold!
